Do I Need An Expansion Tank/setup - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2010, 11:20 AM   #1
Do I need an expansion tank/setup
I will be on city water and will be using an electric hot water heater. I am in the process of installking a 50 gallon hot water heater and need to know if I will need an expansion tank, back flow preventor or anything else. If I do what would be the sequence of installation from the cold water line coming in.
RobertN is offline   Reply With Quote
Old 02-08-2010, 01:11 PM   #2
Expansion tank
If you have a closed system and nowhere for thermal expansion to go than it is a good idea. But if don't have a pressure reducing valve, check valve or anything else that would cause a closed system and if you don't have very high water pressure you should not need one. As for the back flow preventer, rarely do you see them on the water main in residential applications. Maybe on a boiler feed line or irrigation system.
almostdone is offline   Reply With Quote
Old 02-08-2010, 05:21 PM   #3
Irrigation Contractor
Location: South Central British Columbia - The great White North
Check with your municipality. More and more areas are requiring or will require backflow prevention devices.
Do you have a water meter? If you do, you might have a backflow device already installed in the meter. Then you should have an expansion tank.
Mick
Water Guy is offline   Reply With Quote
Old 02-08-2010, 09:47 PM   #4
Licensed Master Plumber
The short answer is yes. By code, you need the tank.
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 02-09-2010, 09:16 AM   #5
expansion tank
Maybe its the code in NH, I think La has their own state PLB. code as does Mass. and the code does not require a tank for water heaters in Mass. It would depend on the code in the particular state your in.
Old 02-09-2010, 10:15 AM   #6
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If there is a check valve at the meter regardless of code or not, you should put one in. If you don't, your T&P relief will "leak"
As for the R/P device, the code in oregon, MINIMUM is atmospheric vacuum breaker. We see the landscapers put in double checks most of the time though. If it has a pump or some means of creating backpressure, however, then an R/P would be required.
Journeyman Plumber
Old 02-11-2010, 08:25 AM   #7
SEQUENCE
1. Main water line entrance.
2. Shutoff valve close to entrance.
3. meter (unless meter outside somewhere)
4. Back flow preventer with check valve.
5. Shut off valve.
6. Expansion tank.
7. Shutoff valve.
8. Continue line throughout house.
SULTINI is offline   Reply With Quote
Old 02-11-2010, 08:35 AM   #8
General Contractor
Check with your local building department as to whether or not you need an expansion tank. We are required to install them here for any structure connected to a city water supply but not on structures supplied by wells.
ARI001 is offline   Reply With Quote
Old 02-11-2010, 08:41 AM   #9
You stalking me?????????????????? Just kidding..
Old 02-11-2010, 08:54 AM   #10
General Contractor
Expansion tank location?? rcassidy HVAC 4 10-06-2009 10:01 AM
Laminate Expansion Gap & Room Size BataviaJim Flooring 7 03-25-2009 07:50 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 06:44 AM
expansion joint farrington135 Building & Construction 1 01-27-2006 11:02 PM
