Do I Need A Check-valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-18-2009, 10:54 AM   #1
Rewards Points: 894
Do I need a check-valve?
Hi;
I need to replace (or hire a plumber to replace) a section of pipe from the output side of the water meter (which is located in the house).
I picked up Rex Cauldwell's Plumbing book at the library, and he talks about a Dual Check Valve that is required by most water utility co.
I do not see a check valve in the line now, unless the long coupling shown in the photo below is a check valve.
Thanks for your advice.
FW
Edit: On second thought; I believe the meter incorporates this device. It is only 3 years old.
Ultrarunner2017 is offline   Reply With Quote
Old 03-18-2009, 12:17 PM   #2
Remodeling Contractor
you do need one and this might be one.
Old 03-18-2009, 05:01 PM   #3
Rewards Points: 894
Actually, from what I have found online since posting, my water meter probably has an internal check valve. Maybe I should e-mail my water utility, unless I can get the model no. from the meter and look up online.
I am going to a real plumbing supply tomorrow to pick up the connector for the meter, so I can ask about a check valve while I'm there. Those guys should know a lot more than the people who work for the big box store.
Edit: I got the spec sheet for my water meter. No mention of a check valve, so I've gotta buy one.
FW
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Replacement Check Valve on Condensate Pump Reilley HVAC 17 02-05-2009 05:57 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 01:36 PM
check valve question burr HVAC 3 11-30-2008 10:03 AM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
