-   -   Do I have the right shut-off valve? (http://www.diychatroom.com/f7/do-i-have-right-shut-off-valve-190422/)
scsiguru 11-15-2013 03:07 PM
2 Attachment(s)
I'm replacing the faucets in my daughter's bathroom and want to replace the shut-off valves. Here's what's installed now:
Attachment 77900
This is what I purchased:
Attachment 77901
Just wondering if what I have to install is not the right kind. Don't want to get into this project and not have the right parts.
djlandkpl 11-15-2013 03:15 PM
Your existing valve has compression fittings on both ends. Your new one does not look to be compression on the supply side. Is the new one threaded on the inside?
scsiguru 11-15-2013 03:16 PM
Yes it is.
joecaption 11-15-2013 03:21 PM
Not the right one. You have no threads to attach it.
You need a 1/2" NOM X 3/8 1/4 turn compression valve. Also change those old supply lines to stainless steel braded. Measure what you have before buy. they need to be at least as long or longer then what you have.
http://www.brasscraft.com/Products.aspx?Id=203
scsiguru 11-15-2013 03:25 PM
Thanks! That's what I was afraid of. Bought these a long time ago planning to do this project and it got put on the back burner. Guess it pays to double check everything before buying. Do the ones you link to just screw into the copper pipe?Can I get something like these at my local big box store?
djlandkpl 11-15-2013 03:33 PM
The valves are available at the big boxes. It's not going to be as simple as unscrewing the old and replacing it wit the new. There is a ferrule inside that compresses the copper pipe to create a water tight seal. You are going to have to cut the pipe so you can use the new ferrule.
If you unscrew the small side your new valve you'll see what I'm referring to.
gregzoll 11-15-2013 03:39 PM
You need to get either a Shark bite or Compression 1/4 turn valve, to replace that old one.
Also if that is 1/2" Copper, you need a 5/8" Shark Bite fitting with a 3/8" top male thread, or Compression fitting. With all of that corrosion on the old valve, you may need to just cut the Copper off right below, since it is most likely frozen in place for that nut.
djlandkpl 11-15-2013 03:45 PM
Originally Posted by gregzoll (Post 1266999)
It looks like you have a "Shark Bite" 1/4 turn.
The fitting is threaded.
gregzoll 11-15-2013 04:01 PM
I looked at it on my phone, and it looked like a Shark bite, due to how bad of a picture. You are correct. The OP needs to either get a compression or Shark bite to fix it.
scsiguru 11-15-2013 08:02 PM
1 Attachment(s)
Here's a little better photo.
Attachment 77908
djlandkpl 11-15-2013 08:08 PM
It looks to me as if the gunk on the valve is coming from above. If you don't want to go to the trouble of replacing the valve you could clean it up and change the supply lines going up to the faucet.
Changing to 1/4 turn valves makes it much easier to shut off the water but how often do you turn off the water(?).
scsiguru 11-15-2013 08:31 PM
I think that's what I'll end up doing. I really don't want to spend the time and money changing out the shutoff valves when I won't be turning them off too often. What's the best way to clean off the green and white gunk?
djlandkpl 11-15-2013 08:57 PM
Try water and some elbow grease.
scsiguru 11-17-2013 09:40 AM
1 Attachment(s)
Job complete...kept original shut-off valves. Didn't want to mess with them since I'll probably be out of this house in about 6 years. The biggest problem I had was removing one of the waste drains. The metal pipe was "frozen" in the PVC. Had to break out the hacksaw to get everything apart. Also, had problems with the new waste drains leaking. Had to reset both but now all ok. Thanks for all the help on this forum.
Attachment 77945
NitroNate 11-18-2013 12:53 PM
like another said, looks like you need a quarter turn 5/8" O.D. (1/2" NOM) inlet by 3/8" O.D. outlet with compression fittings. you bought a threaded one.
cut the pipe before the compression ring, looks like you have plenty of pipe there.
if the current valve is not leaking and it is already a quarter turn valve, you shouldn't need to replace it. if it is not a quarter turn valve, you should definitely replace it. typically, after years and years of never turning the valve, as soon as you close it and then re-open it, it will start leaking. quarter turn valves are far more reliable since they use a ball valve with a nylon seal that will last for a very long time.
