Do I Have To Have A Vent Stack For A Basement Sink? - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-18-2010, 10:40 PM   #1
Do I have to have a vent stack for a basement sink?
I bought a house that had a roughed in bathroom in the basement with what I thought was a bad layout...a toilet already installed then drains on the floor (capped) and a drain/vent a few feed to the left of the toilet. The top drain on the right is a 2" stub that appears to be for a shower/tub, the bottom drain is a clean out for this set and it appears the water from the bathroom above it goes through the same clean out.
I have decided to just do a half because every full bathroom layout in this area doesn't look good. Problem is if I go with the drain/vent then the room will be pretty huge for a half bath. The only option I can see is to use the top right drain and push out the wall slightly for it so a base cabinet will cover the drain. Will this work without proper venting? I'm assuming the floor drain is already trapped (which I will verify) but if it is and I use this drain do trap the sink also? I guess I could have a vent go through the back wall, up and over and meet the existing vent if I had to but I wasn't sure if I needed to for this.
-Allan
Do I have to have a vent stack for a basement sink?-potentiallayout.jpg   Do I have to have a vent stack for a basement sink?-currentdrainlayout.jpg
vseven is offline   Reply With Quote
Old 04-19-2010, 06:56 AM   #2
All fixtures need a vent, or they will drain poorly or not at all.
Installing a trap under the floor seems unlikely, but not impossible. I would still install traps.
Old 04-19-2010, 07:13 AM   #3
Then I guess the question is how do I see if the existing floor drain is vented? I'm assuming it is since it was destine for a shower or tub but how can I verify that?
Vent stack is on other side of basement... Feretich Plumbing 5 02-12-2010 02:13 AM
New vent in basement adpanko Plumbing 1 12-21-2009 10:31 AM
vent stack for kitchen sink Knucklez Plumbing 4 04-02-2008 07:49 PM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
