Do Dishwashers Require A Vent? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-29-2011, 06:27 PM   #1
Lightfoot's Avatar
Rewards Points: 272
Do dishwashers require a vent?
Wife and i are remodeling a rental house. Some of the countertops we've looked at do not show a vent for the dishwasher. Are they no longer required, or are they hidden somewhere now?
Lightfoot is offline   Reply With Quote
Old 06-29-2011, 07:15 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 924
Are you referring to the air gap that is seen on the counter top or sink? They are not required where I'm at. But I have to attach the DW drain line to the bottom side of the counter instead. Most other areas seem to require them though. As for vents- DW do not require them but the fixture it drains to does.
The Following User Says Thank You to TheEplumber For This Useful Post:
Lightfoot (06-30-2011)
Old 06-29-2011, 08:26 PM   #3
The air gap was required where I lived in Oregon, but apparently not here in Maine, so I guess its dependent on your locality. I recently had to deal with this in my new home, where the DW was plumbed wrong in many ways. Make sure that the DW drain hose loops up to just below the counter top, to avoid siphoning of water out of the DW tub. Best way to run the drain is through the kitchen sink drain, as it makes use of the existing trap and vent.
1910NE is offline   Reply With Quote
The Following User Says Thank You to 1910NE For This Useful Post:
Old 06-30-2011, 06:19 AM   #4
Lightfoot's Avatar
Rewards Points: 272
thanks fellas
yes i guess it's called an air gap. My house has one, my previous house had one. It will be plumbed through the sink drain and trap, but i just thought it was odd that no visible vent was apparent. I guess i just worry too much. Thanks again for the replies.
Installing a gable vent..from *inside* the attic steveKane Building & Construction 8 12-09-2012 02:45 PM
Help with basement bathroom vent satchfan Plumbing 3 12-26-2010 09:35 PM
Water Heater Vent Question pd417 Plumbing 1 05-15-2010 12:34 PM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 06:34 PM
