DIY Way Of Cutting PEX - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-18-2013, 02:43 PM   #1
DIY Way of cutting PEX
I don't have a special PEX cutting but need to make two cuts. Is there a good way to make a nice square cut on this stuff? I'll be using sharkbite fittings, so I'm assuming the ends need to be as square as possible.
mopowers is offline   Reply With Quote
Old 01-18-2013, 02:51 PM   #2
Rewards Points: 12,886
About the easyest way by hand would be with a razer utility knife.
Old 01-18-2013, 02:54 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
Buy a tubing cutter.
Coastal South Carolina
Old 01-18-2013, 02:56 PM   #4
I've got one of these. Will this work? I'm making a pex repair in a wall so space is limited. I just want to make sure to get a square cut
Old 01-18-2013, 03:18 PM   #5
Roofmaster
Rewards Points: 2,172
Put a hose clamp on it as a guide and cut it with a utiity knife with a new blade. No thats a close quarters copper cutter. It aint rocket science. I like to chamfer the outer edge just a taste with emory when I use shark bites. Makes the O ring slide nicely. Oh and spit on it before you shove it home.
Old 01-19-2013, 12:31 AM   #6
Or just but the right tool, there cheap enough.
http://www.amazon.com/Everhot-PEX-Pi...+tubing+cutter
jaydevries (01-19-2013)
Do you ENJOY cutting in? DrHicks Painting 66 01-29-2014 10:22 PM
Tips for Cutting Baseboards and Door Trim hellothere123 Carpentry 25 10-20-2012 10:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
Cutting Duct ADKstorm HVAC 10 01-23-2011 02:30 AM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
