Old 08-18-2010, 01:55 PM   #1
DIY Shower curtain rod assembly for a clawfoot tub
I am looking to set up a stand up shower for my clawfoot tub.
Pre-packaged kits are available, but they are RIDICULOUSLY expensive.
I have a fine faucet and handheld shower assembly, so all I need is a rod that encircles the whole tub (similar to the oval or D shaped setups) to hang the curtain on and some sort of holster for the handheld shower.
Why these kits are so expensive it beyond me. I am wondering if anyone out there has constructed their own shower curtain rods, and if so how they did it/what materials they used.
Thank you.
ejcate is offline   Reply With Quote
Old 08-18-2010, 02:10 PM   #2
Thank you.
I wouldn't make one. By the time you get the rod bent, welded, plated, and get brackets for the ceiling, wall and shower head you'll be at big bucks to make it yourself. A quick google search found this at Home Depot's website http://www.homedepot.com/webapp/wcs/...41&marketID=43 and this on amazon http://www.amazon.com/CLAWFOOT-SHOWE...2154782&sr=8-4. Personally I like the one on Amazon better, and a couple hundred isn't a bad price at all
the_man is offline   Reply With Quote
Old 08-18-2010, 04:42 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I once made a great shower for an old claw foot tub in my frat house way back in the "old days". Believe me, I had to do it very cheaply.
I simply hung a small-size pipe rectangle about the size of the tub from ceiling hooks, overlapped three plastic shower curtains hanging down into the tub for the shower "walls" from it, and plumbed the shower head up with galvanized pipe and valves.
It looked "antique rustic" and worked like a charm. I suppose that you could paint the pipe, but I didn't. Can't do it much cheaper than that.
Mike
Mike Swearingen is offline   Reply With Quote
Tags
bath tub, bathtub, clawfoot tub, curtain rod, shower assembly
Tub leaking past shower curtain Outbacker Plumbing 8 12-10-2010 05:15 PM
hanging a shower curtain rod on tile darsunt Plumbing 7 06-22-2010 08:15 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Need Help With Clawfoot Shower Curtain Rods. Pawn3d Plumbing 4 11-21-2009 09:04 AM
shower curtain rail, but sloping ceiling Hazel Interior Decorating 2 11-07-2008 05:46 AM
