DIY Rheem Ecosense Tankless Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2012, 11:21 PM   #1
I need to remove my existing Rheem Ecosense Water Heater model#180DVN, and install a new Rhemm Ecosense model# ECO150 DVN3.
Do I simply turn off the gas, water, and any outside connections then unscrew to box from the wall?
I hired someone to install the original water heater.
Spiders, flies and leaves worked into it and clogged it up.
Gregory
Gregory Johnson is offline   Reply With Quote
Old 06-12-2012, 07:16 AM   #2
It can be a DIY job, but from the nature of your question, I recommend you leave to a pro. Gas leaks can be deadly!!
Old 06-12-2012, 08:17 AM   #3
dogris's Avatar
Gregory
The debris can't be cleaned out?
What's to prevent the replacement heater from having the same fate?
dogris is offline   Reply With Quote
Old 06-12-2012, 10:05 AM   #4
Bill Kearney
Rewards Points: 1,174
Some places do require a licensed professional install gas fixtures. You 'can' do it yourself, pretty much as you've outlined, but you have to decide if your handyman skills are worth more than paying a pro.
wkearney99 is offline   Reply With Quote
DIY gas tankless water heater lofar Plumbing 42 12-19-2010 02:01 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Tankless water heater brewmastr Plumbing 2 01-11-2010 10:35 AM
Tankless water heater vs. electrical water heater? imola ghost Electrical 19 09-08-2008 03:59 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
