Is This A DIY Project? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-23-2011, 11:51 AM   #1
Is this a DIY project?
Details:
Condo - 3rd floor, no one living above
18-20 years old
Until I replaced it, sink is original.
So, I installed a new sink in my guest bathroom. I proceeded to do a water test and it passed...somewhat. Nothing below the sink is leaking, but I heard a DRIP in the wall about 5 feet to the left (behind the toilet tank). I cut the wall open and came to find out that the "T" connection was cracked and leaking (picture attached).
I am thinking, when I installed the pluming under the sink, I disturbed the connection, which is roughly 18 years old and it cracked.
Is this something i can replace?
Thanks for your comments, advise - HAPPY THANKSGIVING!
thatguy59 is offline   Reply With Quote
Old 11-23-2011, 12:27 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 452
If your handy, you can do it, but its not real simple, may by a hiccup along the way- have patience
What you need is a 3 x1.5 PVC santee (if I see the pipe in the picture correctly), 2- 3" ferncos, 1- 1.5" pvc coupling or fernco, short pieces of 1.5 and 3" pvc pipe, glue and primer.
Cut the existing pipes back about 6" or more from the tee. Build the new tee up with matching pieces of pipe you cut out. Glue the 1.5" coupling on the existing pipe. Slip the ferncos completely on the 3" pipe. Slip the tee assembly into position-glue and primer the 1.5" pipe into the coupling. Position the ferncos correctly and tighten bands. Test for leaks.
The Following User Says Thank You to TheEplumber For This Useful Post:
ben's plumbing (11-24-2011)
Old 11-24-2011, 10:01 AM   #3
Rewards Points: 190
Looking at that cracked tee, I can't see how working five feet away could have caused that break. Unless 18 yo PVC gets very brittle, it looks like a very strong downward force parallel to the 3" pipe caused the break such as the building settling. Is there any evidence that it has been leaking for a while? I think it is the condo's responsibility to fix that common element.
zircon is offline   Reply With Quote
Old 11-24-2011, 11:46 AM   #4
Rewards Points: 2,516
What you need is a 3 x1.5 PVC santee (if I see the pipe in the picture correctly).
Eplumber....I may be wrong but to me that looks like a vent tee(straight tee) not a san-tee if I see it correctly. Right.
If he tries using a san-tee and it is a vent tee, there is a little difference in height of the tap as compared to a vent tee.
hammerlane is offline   Reply With Quote
Old 11-24-2011, 01:00 PM   #5
Rewards Points: 1,002
Originally Posted by zircon View Post
Looking at that crack I think it is the condo's responsibility to fix that common element.
Winner
Anti-wingnut is offline   Reply With Quote
Old 11-24-2011, 07:08 PM   #6
Rewards Points: 1,448
Check your condo documents (bylaws, etc.) to see who is responsible.
The most common situation has the condo association covering (all of you owners sharing) the cost of the repair if you did not cause the break and one or both of the following conditions is true:
1. The space in which the pipe is located is between two units.
2. The pipe serves two or more units including for venting.
In addition, in some cities an unlicensed person may not perform plumbing in a building containing more than X dwelling units or a building that contains various spaces owned by different unrelated persons.
Old 11-24-2011, 07:17 PM   #7
Rewards Points: 582
you did not crack this fitting look at the crack its all dark and looks like its been leaking for some time....and if you are handy with plumbing you can fix this ....follow eplumber advice on the repair your in good hands....Ben
Old 11-24-2011, 07:36 PM   #8
Do you guys agree thats not a sanitary tee.
Old 11-24-2011, 07:43 PM   #9
Rewards Points: 582
it looks and old sanitary tee to me ....and the fact that it leaks when you run water through it say its drainage....
Old 11-24-2011, 07:47 PM   #10
Rewards Points: 582
even if it was a vent tee in wrong the repair would be the proper tee all that would happen after cutting tee out it would lower tee from 1.5 center line alittle lower 3" pipe on top and bottom cut 6" away would still connect ok.
Old 11-24-2011, 08:06 PM   #11
you're right...I had a brain freeze. Just cut lower on the stack so tap of the San-T lines up with branch drain
Old 11-24-2011, 08:10 PM   #12
I would say that the most common situation is that the Association owns all the plumbing built into walls
Old 11-24-2011, 08:17 PM   #13
Rewards Points: 582
Originally Posted by hammerlane View Post
you're right...I had a brain freeze. Just cut lower on the stack so tap of the Sant-T lines up with branch drain
hey don't feel bad happens to the best of us i had one "a brain freeze" last week so bad it took my 15 yr old nephew 45 min to release me....ha ha Ben
Old 11-24-2011, 08:21 PM   #14
If it was strictly on a vent, the tee would have been turned upside down. It's a sanitary tee used for drainage and it really isn't a hard fix at all. Maybe 20 bucks worth of material and 30 minutes at most. It has been leaking for a good little while not something that happened in the last couple days
Service plumber is offline   Reply With Quote
Old 11-24-2011, 08:24 PM   #15
You're really assuming the installer would of / should of inverted the San T for venting
My new carport & workshop project mgp roofing Project Showcase 64 01-13-2014 12:57 PM
Timbertech Radiance Rail project Ranger1227 Project Showcase 7 07-29-2011 01:59 PM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 04:07 PM
Anyone used a project manager instead of GC? pulpit Building & Construction 10 02-11-2011 11:08 AM
My basement project - a 2 year project. HABSFAN2006 Project Showcase 14 07-12-2009 10:30 PM
