Old 03-10-2007, 04:31 PM   #1
Brand Newb
DIY jetted tub install
Is a jetted tub a DIY install, or better left to a pro? My plumbing skills are decent. I've done some copper and PVC work before. Just not sure what all is involved with a jetted tub installation. Thanks for the help!
rb_in_va is offline   Reply With Quote
Old 03-12-2007, 08:14 AM   #2
Handyman62010
Doing that one myself too. Test tub before installation or warranty will not cover if there are leaks in unit. Take your time and do it right. If you are not confident you can pull it off though, hire someone for your own peace of mind.
Handyman62010 is offline   Reply With Quote
Old 03-12-2007, 09:19 AM   #3
Brand Newb
Thanks for the info. I have no problem hiring someone if I get in over my head. I have a friend that is a plumber and I will consult him if I need to. I just want it done right.
Old 03-12-2007, 11:50 AM   #4
You will need electrical power for the motor. It should more than likely be on its own circuit with a gfci. The drain should be the same as a standard tub. It is best to have an access panel near the motor if future repair is needed. If the tub is larger in size (volume) then you may want to increase the size of the supply water lines to allow the tub to fill faster.
redline is offline   Reply With Quote
Old 03-12-2007, 12:10 PM   #5
Brand Newb
The tub install is starting to sound like I should get a pro to do it. I feel comfortable with the rest though.
Need to install a water pressure regulator Doug Crf Plumbing 2 06-20-2009 02:23 PM
cutting shingles to install gutters Chicago Bill General Discussion 2 02-27-2009 06:42 AM
Repairing Bad Crown Moulding Install jirishboy Carpentry 10 10-02-2008 10:05 PM
Plantation Shutters: Professional Install or DIY? SlaveToTheWife Remodeling 1 06-01-2007 02:27 PM
jetted tub/shower ajoantmug Plumbing 1 05-06-2007 11:26 PM
