Diverters - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-26-2010, 11:20 PM   #1
CNMDESIGN.COM
Diverters
Putting two shower heads in my new shower. Need a diverter one in, two out.
CNM Design is offline   Reply With Quote
Old 02-27-2010, 09:43 AM   #2
Rewards Points: 352
How about individual controls for each shower head? Is this just a shower or a tub/shower combo?
plumberinlaw is offline   Reply With Quote
Old 02-27-2010, 10:55 AM   #3
CNMDESIGN.COM
It’s a tub with shower. I want to have a regular shower head at 78” and I want to have a ½” nib poking through about 14” below for a hand held unit. I would like to be able to run one or the other. One for taking a shower and the hand for the girls to wash just their hair or give the dog a bath. Hope this helps.
Old 02-27-2010, 12:01 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What type of valve do you have existing in the wall already?
Journeyman Plumber
Old 02-27-2010, 03:48 PM   #5
Rewards Points: 352
screw a diverter with a hand held shower between the shower arm and shower head
Old 02-27-2010, 05:33 PM   #6
CNMDESIGN.COM
I don't like the way that looks.
Old 02-27-2010, 05:34 PM   #7
CNMDESIGN.COM
None, it's all new.
Old 02-27-2010, 05:37 PM   #8
i totaly misread how he said that
The older I get the better I was
Old 02-27-2010, 08:27 PM   #9
Doing it myself
Alan's Avatar
None, it's all new.
So your options are either A ) What was mentioned above (you can get these in matching sets so they look like they were meant to be that way)
or B ) you can put a separate control valve for each
or C ) you can put one control valve for temp and on/off and a 3 function diverter valve (same brand trim will match) so that you can have either shower head, hand shower, or both.
Journeyman Plumber
Old 02-27-2010, 11:56 PM   #10
CNMDESIGN.COM
I think I figured it out.
I bought a shower only kit with two knobs, hot and cold. I will just run it backwards.
I will go from the mixer valve for the tub/shower up to the out port on the second kit and from the hot knob I will go to the shower head and from the cold knob I will go to the hand held unit.
I replaced the hot and cold knobs with diverter handles that match the handle on the mixer.
Old 02-28-2010, 10:00 AM   #11
Doing it myself
Alan's Avatar
That's kind of a bizarre way to do it. . . . . .
I guess it will work.
Journeyman Plumber
