Old 08-23-2009, 01:50 PM   #1
Diverter valve does not extend far enough past surround to install chateau knob-help?
On a very tight budget, this is my first time doing this stuff, and I replaced my 30 yr old shower surround (drywall w/ layer of tile and a glue on surround on top) with a new direct to stud fiberglass unit. The fiberglass unit ended up being about 3/8" to 1/2" "deeper" than the old stack of surrounds.
I'm trying to reuse the existing diverter valve due to a lack of funds, but the diverter valve is only about 5 years old and still good.
Currently the end of the valve sits flush with the surround unit, and I need it to stick out about 3/8" (is there a rule of thumb?) or so in order for my current "chateau handle" to bolt to it. Is there a different style of handle or any sort of "diverter valve extender" I can buy, or am I stuck paying a plumber to come solder in a new valve/pipes? I can post a picture of my shower if it will help answer the question?
Justin311 is offline   Reply With Quote
Old 08-23-2009, 02:49 PM   #2
The valve needs to be moved to the correct depth.
plumber Jim is offline   Reply With Quote
Old 08-24-2009, 10:05 AM   #3
What is this "deep rough in kit" I have read about?
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Tub surround install issue OriginalSterm Remodeling 4 09-11-2008 08:11 AM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 12:16 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
