Diverter Valve Apron - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-08-2012, 01:41 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
I ordered a new rough-in valve for our master suite shower that was leaking and not getting flow from the shower. It finally showed up a week later (what happened to 2 days?) and I go to replace it and the fitting are for compression, not solder. I ordered one for copper pipes. Can I make this work somehow?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 04-08-2012, 09:51 PM   #2
Rewards Points: 582
what type of faucet did you order....
Old 04-09-2012, 11:39 AM   #3
Rewards Points: 150
I'm not sure I understand. All the connections appear to be soldered. The showerhead and bath spout are rigid copper. The supply lines appear to be slightly bent hard copper with 45 or 22 1/2 degree street elbow.
How much play do you have for moving the valve, spout and showerhead up and down?
What is the spacing of the suply lines for the new valve?
Last edited by goosebarry; 04-09-2012 at 12:28 PM. Reason: changed info about supply connection
goosebarry is offline   Reply With Quote
Old 04-09-2012, 11:50 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 924
Usually don't conceal compression joints. Are you sure they are not unions with female IP threads?
Old 04-09-2012, 11:51 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Could you not cut the pipes at the solder connections or close to them and use copper compression fittings to connect it?
Due to limited movement of the pipes you may have to replace the bottom pipe.
sublime2 is offline   Reply With Quote
Old 04-09-2012, 11:55 AM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Look into "shark" fittings.
Many claim they are as good as soldering and can be installerd behind walls.
Old 04-09-2012, 02:09 PM   #7
Fixer-'til-broker
Rewards Points: 262
The new valve is the same, except there are threads in the ports where you would normally solder the joint. The directions say to solder the copper to the brass fittings; this might work for the supply lines, but both the shower pipe and tub spout are also soldered without threads to fit this valve.
I have an idea to replace the lines to the shower and tub with threaded pipe. This means I'll have to bust out a bigger hole in the wall, which I didn't want to do.
Old 04-09-2012, 02:14 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
This wouldn't work for you?
Thread these into new fixture then solder pipe.
Old 04-09-2012, 02:56 PM   #9
Rewards Points: 150
Attachment 48753
Or maybe this?
The connection is probably NPT, not compression.
You should check if your local codes/inspector allow compression fittings inside a wall cavity. They are not allowed in Massachusetts.
I would not recommend Sharkbite connectors for connecting the showerhead. Unlike soldering, the pipe can spin around in a sharkbite connector. The showerhead elbow can work lose becasue of the torque. Again check if your local codes/inspector allows sharkbites in walls.
The Following User Says Thank You to goosebarry For This Useful Post:
Ravenworks (04-14-2012)
Old 04-13-2012, 11:39 PM   #10
Fixer-'til-broker
Rewards Points: 262
Attachment 48753
Exactly what I got, thank you.
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Shower diverter valve prob ProAmateur Plumbing 1 12-27-2010 09:28 AM
Diverter valve does not extend far enough past surround to install chateau knob-help? Justin311 Plumbing 2 08-24-2009 09:05 AM
Diverter Valve Dilema Sasha2000 Plumbing 5 09-15-2008 10:14 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
