Diverging Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-25-2009, 06:18 PM   #1
Rewards Points: 43
diverging water
Hi there!
Hope everyone is having a good day. I have a question regarding the divergence of water.
Well I have bought a cylinder that will act as a water tank. What I want to do is diverge the storm-water that usually goes to the roof to the new tank that I have bought.
Could someone please suggest the best way I could do this? I was thinking of purchasing and installing a "T" shaped pipe with a cock which, when opened, directs the water to the tank rather than the roof.
Please find the pictures attached for further reference.
Thank you for your time.
PS: Image18 (the first picture) is of another connection just in case (I want to connect Image 17 to Image 16)
diverging water-image018.jpg   diverging water-image017.jpg   diverging water-image016.jpg
bugmenot is offline   Reply With Quote
Old 11-26-2009, 06:33 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,030
Ayuh,... Water is coming From the roof, not going To it...
Where does the biege pipe go to after it 90s off the brown downpipe,..??
You could put a "T",+ valve at where the elbow is,... But it'll probably clog up with debris from the roof...
Bondo is online now   Reply With Quote
Old 11-26-2009, 09:50 PM   #3
Diverging water to tank
Not sure where you live and how much rain you get in your area but if you get much rain that tank will fill fairly quickly --- is the tank going to be outdoors like a rain barrel? If it is inside it may quickly fill up and overflow
meboatermike is offline   Reply With Quote
Old 11-26-2009, 10:02 PM   #4
Run the pipe right to the barrel at the downspout - wherever that is
Include a screen to filter out debris
You will need to drill a hole near the top & connect another pipe as an overflow
That 55g barrel will normally fill up very quickly in a rainstorm
I actually have about 750g+ in storage capacity with (2) new 4x4 tanks I just picked up
1 inch of rain on a 1000 sq ft roof yields 623 gallons of water
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 10:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
