Disturbing Epoxied Soil Pipe Joint. - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-25-2010, 08:51 AM   #1
Rewards Points: 91
Disturbing epoxied soil pipe joint.
I attached photos of a soil pipe to the left of, and underneath our kitchen sink. The second one is looking into the cabinet bay, the first was taken at the P-trap under the sink, looking down the pipe. It looks like someone very sloppily tried to fix a leaking problem at some point by epoxying the joint between the pipe and another smaller fitting on the right.
I am going to be installing a garbage disposal soon. My concern is that during the course of install, I may disturb the epoxied joint and cause leaking, or even damage the soil pipe.
Do I need to address this joint anyway, since it looks like a bad patch job?
If not, any ideas how to better support the pipe to minimize damage while I do work under the sink?
Thanks in advance.
Disturbing epoxied soil pipe joint.-img_4368.jpg   Disturbing epoxied soil pipe joint.-img_4367.jpg
debiasio is offline   Reply With Quote
Unused underground soil pipe. hebes99 Plumbing 6 04-07-2010 12:32 PM
Foul smell from soil pipe? abaminog Plumbing 3 03-31-2010 01:15 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
PVC drain pipe leaking at joint, 2 part epoxy last? harleysilo Plumbing 3 09-26-2006 01:29 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
