Distance From Toilet To Vent. - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-07-2012, 12:17 PM   #1
Distance from toilet to vent.
Hello all. We have demolished our bathroom and are in the process of redoing some of the plumbing. What we would like to do is move our toilet about 5 ft to the other size of our small bathroom in order to make room for a double vanity.
The original drain was 1 foot from the soil/vent stack. Moving it to the other side of the room would put the overall distance at 6 feet from the bathroom vent. From what I have gathered, if a toilet with a 3 in drain line is within 5 feet from the vent, it meets code and should be acceptable. My question is if anyone has had any experience with a toilet 6 ft from its vent having problems flushing/clogging etc. If so, is 5 ft anymore acceptable than 6 ft or is this an example of the code falling short.
My other option would be to run a seperate vent for the toilet up into the attic and tie back into the original vent. Would this be acceptable with a 7 ft horizontal stretch before meeting back up with the stack?
I should also mention that it is a 2 in vent that will serve the toilet, a double vanity, and a shower.
Thank you in advance for any help. Cheers!
Rclancyc is offline   Reply With Quote
Old 06-08-2012, 12:11 AM   #2
Rewards Points: 636
yes it will work just fine
http://publicecodes.citation.com/ico...2_9_sec009.htm
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 06-08-2012, 03:06 AM   #3
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
your allowed 6 foot trap arm on 3", 5' on 2" and 42" on 1 1/2 pipe and if your 5' or less off your main you don't need a clean out. but u can check your local code enforcement office
wctekkk is offline   Reply With Quote
Old 06-08-2012, 10:30 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Also a note : the trap arm on a toilet is measured from the surface of the flange along the centerline of the pipe to the edge of the vent pipe.
Journeyman Plumber
Old 06-11-2012, 05:25 AM   #5
Sorry it took me so long to reply, my computer was on the fritz.Thank you all so much for the input, I'll let you know how it turns out after in the end. I get the feeling i'll be back asking for advice before it is all done!
Old 06-11-2012, 08:54 AM   #6
Rewards Points: 3,130
If your local code is the IRC (as it is where I live), there is no limit to trap arm length for a toilet. Nor do toilets, regardless of trap arm length, need a vent other than the main stack.
Old 06-18-2012, 03:44 PM   #7
I just did a little research and it turns out that we use UPC here in Austin. From what I understand, I am still allowed 6 feet from vent on a 3 inch drain line. wctekkk mentioned that if the line is over 5 feet, I would need a clean out. Are there any suggestions as to where a clean out ought to be placed in the crawlspace? I only have about 20 inches headroom in crawlspace in the event I needed to get messy with a clog. Do they sell closet bends with a clean out opposite the drain line? I'm not sure where I'd even be able to put a clean out that would be accessible.
Old 06-19-2012, 02:12 AM   #8
Plumber
TheEplumber's Avatar
Rewards Points: 452
I plumb by UPC and am not required to have a clean out on the toilet arm, even at 6'. We don't consider it a branch line, which require clean outs if over 5'. You'll pull the toilet to clean that line anyways. Also a clean out in the crawl must be within 20' ft. of the access.
Old 06-19-2012, 10:13 AM   #9
Doing it myself
Alan's Avatar
The reality of the situation is that generally if you have a problem with a mainline, you're not going to use a cleanout underneath the house even though they may be required.
Journeyman Plumber
Old 07-30-2012, 04:34 PM   #10
Thanks for all the help! The toilet lines is installed, I sweated all the new copper supply lines together, and just minor adjustments left for the shower drain. Now on to the tedious part...finishing it!
Tags
distance , plumbing , toilet , vent
Shower / Toilet Vent bigmatt Plumbing 2 12-05-2010 07:25 PM
Vent line for toilet eahosea Plumbing 7 12-03-2009 10:35 PM
Stack Distance From Toilet jonathan03 Plumbing 8 02-02-2009 07:37 PM
Upstairs toilet pipe noise bliss Plumbing 8 01-10-2008 08:55 AM
toilet vent problem? docholaday Plumbing 8 06-21-2007 06:05 PM
