Distance To Stack - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-21-2007, 11:16 PM   #1
Distance to stack
Hi there.
Im moving my sink 3 feet further away from the stack/drain tee off.
Its an older house where the (2' outside dia/cast iron) drain pipe runs into a vertical pipe and the stack runs directly up from this through the roof. The new distance will be a total of 6 feet from the trap to the stack.
Will I need to bring the stack closer and if so can I tap into the exsisting stack above the drain junction and move it over and tee in closer to the trap.
I hope this makes sense.
Thanks in advance.
Rusty
rusty_5620 is offline   Reply With Quote
Old 02-21-2007, 11:19 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
Too far from vent at 6', you will need to run a new vent back to the stack within 5' providing the trap and arm will be 2", if trap and trap arm is 1 1/2" then the distance to vent is 3'6"
This is under UPC Code.
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 02-21-2007, 11:33 PM   #3
Distance to the stack.
Thanks Ron.
I'll bring her in at 3'6".
Last time I was down your way was to watch a Ducks game.
Had a blast!
Cheers,
Rusty
Vancouver,BC
Old 02-21-2007, 11:35 PM   #4
Journeyman Plumber
You understand that is for the vent, once you hit vent, then it does not matter for distance to main.
Old 02-21-2007, 11:39 PM   #5
Distance to stack.
Yep,
I gotcha.
I take it you just have to get that air in behind it. (the sooner the better)
Cheers,
Rusty
Bathroom outlet - distance from tub?? plbsplbs Electrical 11 07-09-2007 08:22 PM
Soil stack "cover"? DIYGmaLynn Plumbing 3 09-04-2006 12:23 AM
tub drain maximum distance redline Plumbing 3 08-19-2006 08:20 AM
DWV Stack Question dcgray2 Plumbing 9 07-14-2006 12:56 PM
siding distance from shingles? matchupeabody Roofing/Siding 13 11-01-2005 09:31 AM
