Distance From My House To My Well. - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2011, 04:33 PM   #1
Distance from my house to my well.
I am wondering how far I can have my well from my house? Will it matter up to a certain point? If it does do I just have to put an in line booster pump in or something like that?
DK
kuebeck89 is offline   Reply With Quote
Old 04-09-2011, 07:23 PM   #2
DIY staff
Rewards Points: 7,174
The distance should not matter a bit----Are you in a cold climate? I'd be sure the waterline is well below the frost line.
How far away from the house is the well?
Old 04-09-2011, 07:49 PM   #3
I am in MD so it doesn’t get dramatically cold but I am probably 600ft from the well. I am building a new house and going to use the existing well. Is there anything that I should upgrade or do?
DK
Old 04-09-2011, 08:19 PM   #4
DIY staff
I have a well---and a good knowledge of plumbing----However, I am not an expert in this area.
Let's keep this post near the top until someone with a lot of experience checks in.
In the mean time----what do you know about the well-----Type of pump? Depth?
----Mike-----
Old 04-09-2011, 08:27 PM   #5
I know it is 265ft deep put in the ground in 1989. No idea about the pump. We currently use it now for the trailer that we live in but we only have 1 bathroom and 1 kitchen sink that we use.
Old 04-09-2011, 10:41 PM   #6
DIY staff
That's a nice deep well. Mine's 135 deep---Come on well guys---I'm over my head here--Help answer this fellows question.----Mike----
Old 04-10-2011, 11:32 PM   #7
Rewards Points: 56
I suspect that the size of line you use for that length of run is going to be more of a factor than the pump itself, particularly for one sized for that depth, but the well driller should have records indicating the pump that was used, and then you should be able to check the manufacturer's website, or call them, for the spec's on your model number.
Old 04-11-2011, 11:22 AM   #8
Household Handyman
Rewards Points: 1,408
The size of the pump will be critical here. The rate horsepower (HP), the gallons-per--minute (GPM) of flow, and the head pressure will some of the determining factors with you 600 foot distance. Head pressure has to do with how much water you will have at a give pressure at a give height above pump. You may even be required to install a separate water tank at the well site for storage and to build up water pressure to push the water the 600 feet at the nominal pressure for your home. I highly suggest you find whomever put this well in, your local county's records should show this as it is deemed "potable water".
Old 04-12-2011, 04:38 PM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
A couple of considerations. I assume that the well and pump set up works for the trailer. Is there any significant difference in elevation between the trailer and the new house? 1/2" pipe or perhaps even 3/4" won't like that 600' distance. You'll get some serious pressure loss while under flow, so plan on bumping up your pipe size. Also you need to consider the electrical requirement. 600 more feet could give you some serious voltage drop unless you size the wire correctly. And you'll want that 600' in one run. You don't want to have buried splices giving you fits a few years down the road.
Old 04-14-2011, 03:45 PM   #10
What size of pipe would you recommend that I run?
My house's previous owner - DIY horror stories Leah Frances General DIY Discussions 153 01-21-2016 08:18 PM
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
Trane XR12 1.5 ton-Too small for my house? Badfish740 HVAC 7 09-23-2009 06:48 AM
I have Central Heating & Air, but house won't cool down..HELP!! exiledone1 HVAC 13 07-10-2009 11:09 PM
Some walls rattle in my house if hit with something, I will explain inside posting zincmann Building & Construction 4 11-10-2008 04:05 PM
