Distance In Front Of Shower - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-06-2014, 04:58 PM   #1
Rewards Points: 236
Distance In front of Shower
So, I had my underground inspection. Before the inspection, I drew my shower tray layout on the concrete so that the inspector can comment on. The inspector measured the distance between the edge of the tray and the toilet pipe. The inspector approved my underground pipe, and he said I have sufficient space (I can't remember the exact number 13" while I have 15"). But, then I read a code states that "A minimum space of 24 inches must be planned in front of a shower entry."
Can anyone explain what the code is trying to say?
Btw, I live in Prince William county, VA.
325_man is offline   Reply With Quote
Old 07-06-2014, 05:19 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 350
You need 15" from the center of the toilet to the next fixture, cabinet, wall, etc. In other words, a toilet requires 30" of clear space.
You need 24" clear in front of the shower - to enter or exit.
There are also minimums forin front of toilets and lavs
Old 07-06-2014, 05:29 PM   #3
Rewards Points: 236
My toilet is by the shower tray which was planned for a tub by the builder. Other than the 15", do i need to cleat more space (i.e. Additional 24") from the tray?
Old 07-06-2014, 06:49 PM   #4
Rewards Points: 1,700
417.4.2 Access. The shower compartment access and egress opening shall have a minimum clear and unobstructed finished width of 22 inches (559 mm). Shower compartments required to be designed in conformance to accessibility provisions shall comply with Section 404.1.
What that means is the shower opening must be a min. of 22 inches for access to the shower.
405.3.1 Water closets, urinals, lavatories and bidets. A water closet, urinal, lavatory or bidet shall not be set closer than 15 inches (381 mm) from its center to any side wall, partition, vanity or other obstruction, or closer than 30 inches (762 mm) center-to-center between adjacent fixtures. There shall be at least a 21-inch (533 mm) clearance in front of the water closet, urinal, lavatory or bidet to any wall, fixture or door. Water closet compartments shall not be less than 30 inches (762 mm) wide and 60 inches (
What the bold means is what it says. 21 inches from the installed fixtures.
Old 07-06-2014, 06:56 PM   #5
Rewards Points: 236
Or, it means as long as there is at least 24" opening in front of the shower tray?
In other words, the toilet will not block the shower tray (48" long) all the way.
Old 07-06-2014, 06:59 PM   #6
Are you installing your toilet in front of your shower access. Please post your fixture layout.
If you have
SH WC Lav
and the shower is 48 inches long
When you install a toilet is that fixture in the way of you getting into the shower?
Use some common sense?
An average toilet will hang out about 31 inches from the wall. That is why most builders add dead space on the toilet side of the shower.
If your comfortable with that its your house. We are not doing commercial construction here.
Old 07-06-2014, 08:10 PM   #7
Rewards Points: 236
Yes, the toilet is designed to be in front of the shower. See the attached lay out.
I think most of the elongated toilet is 27.5."
Do you think the inspector will fail me?
Name:  Shower Toilet Dimension1.jpg
Old 07-06-2014, 08:45 PM   #8
Rewards Points: 236
Attached is another image from different website which confuses me.
The problem is that my other bathrooms don't have this much of room between the bathtub/shower and toilet.
Old 07-07-2014, 12:20 PM   #9
Personally I would want more space in front of the toilet. With a 5 foot tub you leave 29 inches. With a 4 foot shower tour down to 17 inches and a tight squeeze. The toilet measurement I got came from a Mansfield elongated toilet.
The major problem you have is you do not have the 21 inches in front of the toilet itself. Do you plan on resting your knees against the wall when you use it.
If I inspected you I would turn you down.
Old 07-07-2014, 12:30 PM   #10
Rewards Points: 236
Thanks Ghostmaker!
The problem is that I move the wall out to get the comforting 24", the hallway outside the bathroom will be only 30" to 31".
So, that is my dilemma. Which one is more important code wise. The bathroom or the hallway?
Old 07-07-2014, 01:00 PM   #11
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 424
From the closed bathroom door to the shower looks to be over 4'. Way more than 24" in front of it.
With my Toto toilet, I need 50-51" to maintain 21" in front of it. Other toilets may be shorter depth wise.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is online now   Reply With Quote
Old 07-07-2014, 03:56 PM   #12
Since I'm not the one inspecting you. It's up to him if he even notices it. So do not volunteer the info.
The Following User Says Thank You to Ghostmaker For This Useful Post:
carpdad (07-08-2014)
Old 07-08-2014, 09:15 AM   #13
Rewards Points: 324
I keep saying inspectors are people too.
Don't worry about the shower room. If you can sidle your way to it, you will pass.
Toilet spacing is for access for all kind of people, and set for 30" with toilet in the center. Inspectors check this only.
carpdad is offline   Reply With Quote
Drain to P-trap minimum distance in shower stall ryan112ryan Plumbing 1 03-15-2014 04:42 PM
Button broke on Shower Head that redirects water to Handheld Massager ace2013 Plumbing 2 01-19-2014 10:18 AM
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 08:23 AM
Shower Leak Herk_Man Plumbing 10 04-14-2013 05:19 PM
Shower grout discoloration Teebadoe Kitchen & Bath Remodeling 2 11-03-2010 08:07 PM
