Distance Of Drain Line From Wash Machine To Main Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-17-2013, 11:11 PM   #1
Distance of drain line from wash machine to main drain line
Hello; I am installing a new wash machine in the garage and the distance from the drain line to the other point of connection inside the house is 64 feet approx. Is the distance o.k. ? Also, I want to install 3 inch pipe with
one 45 degrees turn because of the long distance. Is that o.k. ?
Also, The slope for 64 feet is going to be 16 inches difference; do you think I can do it with a lesser slope? For example. 1 inch for every 6 feet which wil give me a total of 10 inches slope approx. ? Thank You
Gabriel8642 is offline   Reply With Quote
Old 11-18-2013, 12:27 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
I believe LA is UPC code so 3" is ok for size and length.
A full size cleanout is required at the end of the run- at the washer.
You can have 1- 90 and 1- 45(135 degrees) before additional cleanouts are needed
3" needs 1/4" per ft grade to pass inspection
The washer trap is 2"
Hope this helps
Old 11-18-2013, 06:41 PM   #3
Rewards Points: 2,104
its cold outside.... ooppsssy
Old 11-18-2013, 09:29 PM   #4
Master Plumber
Javiles's Avatar
Rewards Points: 996
82 today .....send down a little cold air but not too much.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
How to vent washing machine drain line nateo Plumbing 1 12-31-2012 04:43 PM
New Guy Here. Main water line question... Freestyler Plumbing 8 11-26-2012 07:59 AM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-22-2006 11:13 PM
Main drain line lmanwarren Plumbing 1 04-06-2006 12:32 AM
