Distance Between Fittings When Soldering With Copper - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-11-2010, 02:34 PM   #1
distance between fittings when soldering with copper
Is there a standard distance to put between fittings when soldering a copper plumbing system?
We are afraid that putting the fittings too close together will result in us melting a finished joint while trying to solder a new one. At what distance does this become safe?
Thanks,
Kelly Durfey
Kelly Durfey is offline   Reply With Quote
Old 06-11-2010, 06:00 PM   #2
Rewards Points: 150
As long as you can see the joints with enough room to get the solder in (fittings shouldn't touch each other) it should be fine, real close joints you solder them at the same time.
braindead is offline   Reply With Quote
Old 06-11-2010, 06:02 PM   #3
Rewards Points: 1,910
No distance required.
Put the whole thing together, if it fits good then take it apart, clean and flux all pieces, assemble. Then start soldering moving from 1 joint to the next adjacent joint till done.
Old 06-11-2010, 06:06 PM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Agreed with above. If they are new joints and you are putting them together, measure, cut, assemble all at once the fittings that are close together, and solder all at once.
IF you are trying to solder next to an old joint, your best bet is to stay a few inches away from it and put a cold wet rag on the old joint while you solder your new one.
Journeyman Plumber
The Following 2 Users Say Thank You to Alan For This Useful Post:
oh'mike (06-11-2010), secutanudu (07-02-2010)
Old 06-14-2010, 11:02 AM   #5
Cool. Thank you guys (and/or gals). That's exactly what we needed.
I love this website!
Connecting copper pipe without soldering? mikedavid00 Plumbing 14 04-07-2010 11:30 PM
Anyone using Ridgid Propress & press fittings? -For Copper NOT PEX- ChrisDIY Plumbing 2 03-30-2010 10:38 AM
Soldering Copper chimney flashing buzzymalone Roofing/Siding 10 08-10-2009 09:28 AM
When soldering copper, what causes the solder not to "suck in"? Piedmont Plumbing 10 10-25-2008 09:59 AM
Copper Soldering Problem Eric_ht Plumbing 4 09-08-2008 09:17 PM
