Disposer Height Above Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2013, 04:55 PM   #1
Rewards Points: 48
Disposer height above drain
Just bought a deeper sink and am concerned about the height of the disposer. Looking at my current setup, I have 2 inches difference from the disposer drain height and the line into the wall; my new sink is 2 inches deeper so it looks like they will be even.
1. Is it ok for the disposer two to be the same height? I know it can't be lower.
2. Any reason looking at my current setup would not reflect the final heights with a new sink? I intend to put the new sink in and use the existing drain and disposer, so figured I don't need to measure anything else (except for the trap).
boogie81 is offline   Reply With Quote
Old 10-13-2013, 06:34 PM   #2
DIY staff
Rewards Points: 7,174
You may be in trouble----be prepared to open the back of the cabinet and lower the drain----when that time comes---post a picture and we will help===Mike
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
ben's plumbing (10-13-2013), plummen (10-13-2013)
Old 10-13-2013, 08:08 PM   #3
Rewards Points: 236
just try it and see what happens.
Fix'n it is offline   Reply With Quote
Old 10-14-2013, 10:31 AM   #4
Rewards Points: 48
i found a message board where someone said they installed at the same height and they say water pools in the disposer. however, i also foun a Bob Vila video where they dealt with a deep sink and it appears they installed the disposer at the same height as the waste drain (link below, beginning at 2:20; see drain heights at 4:10 and on). i'd like to believe Mr. Vila did a correct install and that this would solve my problem, but would like more input for any pros on here.
http://www.bobvila.com/sections/tv-s...rbage-disposal
The Following User Says Thank You to boogie81 For This Useful Post:
jmon (10-14-2013)
Old 10-14-2013, 07:35 PM   #5
DIY staff
I watched the video---Bobs 'plumber' did screw up the install--the unit will hold sewage and drain poorly until it clogs up.
The ragged cuts ,installed without removing the shredded edges makes me think that is not a plumber--Mike---
Old 10-14-2013, 08:33 PM   #6
Rewards Points: 48
thanks for the reply. turns out the disposer outfall would be 3/4" higher than the waste line. think that 3/4" height difference would be enough for adequate drainage?
i'd be willing to install and lower the waste line height later, if needed, but my current setup is two waste lines back into the wall that turn immediately once in the wall and join in the center (presumably). seems i'd have to take more wall out and do even more plumbing to lower the height (i'm putting in single basin).
Old 10-14-2013, 09:40 PM   #7
DIY staff
put a P-trap onto the garbage disposer and see what the drop is---
I have to lower a lot of drains every year---some are easy (the drains that go down)
others are a pain in the rear (pipes the go horizontally before going down)
Old 10-15-2013, 01:24 PM   #8
Plumber
That guy is a total HACK !!
Now that every thing from the disposer to the wall is solvent welded, how in the world are you going to get a cable in there to clear the blockage that coming very soon ?
I cant believe that Bob put that up as the "correct way" to do it.
DidIDoThat is offline   Reply With Quote
Old 10-15-2013, 06:33 PM   #9
DIY staff
Hey, it's on T.V. so it must be right!
plummen (10-15-2013)
Old 10-15-2013, 06:39 PM   #10
Rewards Points: 1,946
Love that super deep trap fix. Should be cleaning that out on a weekly basis. But if old bobby says it is good must be. Illegal install hack plumber bobby...
Your most likely will have to lower the drain outlet in the wall.
The Following User Says Thank You to Ghostmaker For This Useful Post:
Old 10-15-2013, 07:55 PM   #11
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Because bob villa was a total hack,you never saw him actually do any work on the show.
He just walked around bugging everybody else.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
The Following User Says Thank You to plummen For This Useful Post:
oh'mike (10-16-2013)
Tags
disposal , disposer , kitchen drain , kitchen sink , plumbing
Bathtub Drain Leak atm Plumbing 6 08-24-2013 07:48 PM
Proper Slope for Sump/Gutter Drain dankoos Plumbing 0 05-06-2013 12:59 PM
setting a shower drain Jackets Plumbing 16 05-10-2012 08:48 PM
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
