Old 01-17-2011, 08:08 PM   #1
Disposal torque removes plumbers putty
installed new garbage disposal. when turned on, the torque twists the sink flange slightly. wore away the plumbers putty within a couple of weeks. I can reinstall the disposal with fresh putty, but need a longer term solution. is there another option, such as a gasket, that can seal the flange?
cpowersr2 is offline   Reply With Quote
Old 01-17-2011, 08:17 PM   #2
Picky Plumber
doesn't sound like it's tight enough. i've never ran across that before. what brand?
Plumber26 is offline   Reply With Quote
The Following User Says Thank You to Plumber26 For This Useful Post:
braindead (01-17-2011)
Old 01-17-2011, 08:25 PM   #3
i'll pull it apart and reapply plumbers putty - how do I know that the flange is tight enough?
Old 01-17-2011, 08:35 PM   #4
Picky Plumber
When you can no longer manually rotate it.
Old 01-17-2011, 08:46 PM   #5
Thanks for your help - I'll take another shot at fixing it
Tags
disposal sink flange
Plumbers putty or Silicon Caulk? sukhenkoi Plumbing 2 04-21-2010 07:51 AM
Replaced Faucet. Now water smells of plumbers putty! emperor_black Plumbing 10 03-04-2010 09:19 PM
Clear Silicone instead of Plumbers Putty jmacx81 Plumbing 2 04-29-2009 07:14 AM
Plumber's Putty around sink flange DIYGST Plumbing 6 02-03-2009 08:18 PM
Shouldn't use plumber's putty on acrylic tubs?? jayp Plumbing 1 06-10-2008 11:03 AM
