-   -   disposal sink flange without the disposal? (http://www.diychatroom.com/f7/disposal-sink-flange-without-disposal-70123/)
wolfv 04-29-2010 02:30 AM
I removed a broken garbage disposal unit from my kitchen's double sink.
I don't want a garbage disposal; and plan to install a drain pipe in it's place. Sounds like a simple project. Now here is the complication:
The two sink flanges of the sink match the color of the sink (tan).
I would like to keep the color of the original sink flange, but all the sink flanges at the hardware store are chrome (not tan). So I want to use the original disposal sink flange (tan), but without a disposal attached.
Is there a way to connect the disposal's sink flange to a drain pipe? The disposal's sink flange has a much wider inside diameter than the 1 inch drain pipe. Is there an adapter to connect a disposal sink flange to a 1 inch drain pipe?
Thank you.
oh'mike 04-29-2010 05:03 AM
Sorry--you're out of luck on that idea.
Tan trims are easily available--You will have to make a few calls.--Mike--
Just Bill 04-29-2010 06:24 AM
The color is usually bone or almond, but as he said, basket strainers are available in those colors. Try big box and plumbing supply stores.
