Disposal Only Draining When On - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-10-2012, 11:15 PM   #1
Rewards Points: 87
disposal only draining when on
I have a fairly new garbage disposal.
Everything works fine except that it only drains when I have it turned on. It is in a double sink with the disposal side smaller and shallower.
The larger side drains fine and the disposal drains fine, just only when on.
When it is turned off a little bit of water will flow back into the base of the disposal.
I am not sure if I have had this problem long as when the previous disposal died my friend who was renting the house failed to replace it (too difficult for them....)
From what I have read this could be something like the disposal drain being in the wrong location or the ceiling vent being blocked?
Any suggestions on how to diagnose and fix this problem?
hellonoko is offline   Reply With Quote
Old 08-10-2012, 11:43 PM   #2
Could you re-size that pic so it it's a small enough to fit on the screen without having to scroll all over the place? It's pretty tough to see what's going on there.
VIPlumber is offline   Reply With Quote
The Following User Says Thank You to VIPlumber For This Useful Post:
Alan (08-10-2012)
Old 08-11-2012, 12:14 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 350
Right click on the image and select open in new tab
Old 08-11-2012, 02:15 AM   #4
Rewards Points: 87
resized. sorry about that.
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
New Garbage disposal draining slowly. yoeye82 Plumbing 1 12-10-2010 04:40 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 12:39 PM
slow draining garbage disposal lchiu7 Plumbing 3 04-05-2009 04:00 PM
Disposal not draining except when on doyledh Plumbing 8 10-22-2008 10:13 PM
