-   -   Disposal not draining except when on (http://www.diychatroom.com/f7/disposal-not-draining-except-when-30388/)
doyledh 10-22-2008 04:55 AM
We're renting a house and having problems with a disposal that will not drain the water from the Dishwasher unless the disposal is turned on.
I suspect a faulty installation. It is a new disposal. The first time it was installed (by an old friend of the landlady) he left the plug in the drain FROM the DW. This time I can't tell what the problem is, but the water coming into the disposal will not go out unless the disposal is turned on.
It is a Kenmore disposal.
Termite 10-22-2008 09:02 AM
I have the same problem and haven't managed to figure it out either. Ruled out the drain itself, which is running clear.
I have yet to pull the disposer and open the drain port on it, but I suspect that's the area that's plugged up. You might try that before you consider replacement.
doyledh 10-22-2008 09:54 AM
Disposal drain
The disposal is new and an alleged plumber installed it. There were also some other plumbers who were clearing out the drains and they could not figure out the problem. The drain is clear and water goes down it, but ONLY when the disposal is turned on it appears. There has to be some valve that closes when it is off.
Termite 10-22-2008 09:56 AM
Not to my knowledge.
jogr 10-22-2008 02:47 PM
When you run water into the disposal with the disposal off does it drain or does it back up into the sink?
doyledh 10-22-2008 03:39 PM
disposal
It backs up into the sink. It drains only when the disposal is on.
jogr 10-22-2008 04:47 PM
When you turn on the disposal it acts as a cenrifugal pump and forces the water through any blockage. When the disposa is off water should still drain freely so if it doesn't there is a blockage somewhere.
It could be that fibrous/greasy debris is plugging up the disposal. Try grinding a bunch of ice cubes and see if that helps.
Does the disposal have it's own p trap or does it share a p trap with the other side of the sink? If it has it's own p trap it may be clogged.
doyledh 10-22-2008 09:03 PM
disposal
I'll give the ice cubes a try ... then call the land lady.
It makes sense that something is clogging it, and that the disposal is acting as a pump. What does not make sense is how the plumber and drain cleaner could have missed clearning that part of the drain. It has to be in the J trap because it fills rather soon with water. It is a single sink by the way.
Many thanks for your help.
InPhase277 10-22-2008 10:13 PM
I had a verrrrrry slow draining disposal due to bacon grease. I boiled a big ol' pot of water, and CAREFULLY poured it down the disposal. A little while it wasn't running, and more while it was. Cleared that sucker right up. Of course, big pots of boiling water are no joke. Don't go tripping on rugs or have the toddler running under your feet when you do this.
