Disposal Mystery... - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-02-2012, 10:40 AM   #1
Disposal Mystery...
Anyone run into this before?
Dual sinks. Garbage disposal is functioning but sink won't drain. Motor is running, blades are turning, but water is backed up into the sink.
Drain pipe is not clogged anywhere along the line. When I remove the small 90 degree tube from the disposal and poke a screwdriver into the opening water pours out.
Weird
Rjc8513 is offline   Reply With Quote
Old 12-02-2012, 12:04 PM   #2
Rewards Points: 6,652
Disposal is the culprit. If it is old, time to change it out. You can take it outside and flush with a couple of buckets of hot water, after pouring Baking Soda & Vinegar into it and letting it sit for about ten min's.
Old 12-03-2012, 07:06 AM   #3
Rewards Points: 1,216
Is the dispoal brand new?
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 12-03-2012, 07:17 AM   #4
DIY staff
Rewards Points: 7,174
Chopper blades missing??
Old 12-03-2012, 08:34 AM   #5
Rewards Points: 1,452
Originally Posted by Rjc8513 View Post
... Garbage disposal is functioning but sink won't drain. Motor is running, blades are turning, but water is backed up into the sink.
Drain pipe is not clogged anywhere along the line. When I remove the small 90 degree tube from the disposal and poke a screwdriver into the opening water pours out.d
The disposal is clogged inside.
The age old disposal issue - high drain hyunelan2 Plumbing 12 02-21-2013 06:20 PM
disposal only draining when on hellonoko Plumbing 3 08-11-2012 02:15 AM
switch to garbage disposal question tard01 Electrical 64 03-30-2012 06:19 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 12:39 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
