Old 04-14-2011, 07:06 AM   #1
Disposal location
In a large double stainless steel sink where should I put the disposal in the small sink part or in the big one? Can I use a doble p-trap? If I put it on the big part of the sink is deeper and I will have to use a doble p-trap.
EHouse is offline   Reply With Quote
Old 04-14-2011, 07:29 AM   #2
Disposal location
Drain connections are simpler if the disposal is in the shallow bowl. Ideally, only one trap is needed for the two bowls, which also simplifies the installation.Can it be done as you suggest, yes.
Disposal wiring Shammie Electrical 6 03-09-2011 12:21 AM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 12:39 PM
Dishwasher/Garbage Disposal + Plumbing AZLambdaK1 Plumbing 5 06-18-2010 12:11 PM
disposal sink flange without the disposal? wolfv Plumbing 2 04-29-2010 07:24 AM
Disposal not draining except when on doyledh Plumbing 8 10-22-2008 10:13 PM
