Disposal Leaking - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-26-2011, 09:54 PM   #1
Rewards Points: 14
Disposal leaking
I just replaced the sink flange that is connected to the garbage disposal, and the disposal is leaking upon reassembly. It does not appear to be from the flange, on which I used plumbers putty, but seems instead to be at the top of the disposal... as circled in the photo. It was darn hard getting that thing back up in there, but it seemed to be all done correctly. It is on tight. Is there something I am doing wrong, something that needs replacing, or is the disposal history?
Thanks for your help!
-- Jeff
mntentman is offline   Reply With Quote
Old 09-27-2011, 06:33 AM   #2
You either don't have all three of the lugs in place or the clamp ring is not rotated far enough to tighten fully. It could also be a damaged rubber seal.
The Following User Says Thank You to Just Bill For This Useful Post:
mntentman (09-27-2011)
Old 09-27-2011, 07:23 AM   #3
Rewards Points: 14
Thanks, Bill. I know the lugs are on, because the first time I missed on. And it's tight. So that leaves only one final option. Well, this is an old unit anyway...
Garbage disposal leaking from bottom abefroman Plumbing 16 09-11-2010 11:50 PM
Leaking connection between disposal pipe and drain pipe in kitchen geniusintx Plumbing 1 07-06-2010 04:14 PM
Water leaking from under disposal/Installing new disposal quadari Plumbing 6 06-29-2010 11:39 AM
Leaking kitchen faucet!!! And disposal question... Beth777 Plumbing 9 08-30-2008 06:57 PM
Garbage disposal leaking ArizonaNick Plumbing 3 12-26-2007 04:22 PM
