Dismantling A Commercial Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-08-2006, 09:27 PM   #1
dismantling a commercial toilet
can the toilet be taken out without turning off the water throughout the entire house?
katmandu is offline   Reply With Quote
Old 07-09-2006, 01:20 AM   #2
Long-Time DIYer
Mike Swearingen's Avatar
IF it has a water supply shut-off valve at the wall or floor behind/below the tank. Otherwise, you will need to turn off the main.
If it doesn't have its own shut-off valve, install one after you turn the water main off, and then turn the rest of the house back on. If it's copper supply line, you can use a compression valve without soldering anything.
All fixture supply lines, hot and cold, should have their own shut-off valves.
Also, a toilet has a built-in trap, so if you temporarily remove it, stuff a rag into the closet bend pipe (flange) to prevent sewer gas from entering.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-09-2006, 03:27 PM   #3
removal of commercial toilet
Thanks for the quick reply. But I want to make sure you are aware that this is a commercial toilet - it doesn't have a water valve at the base. Thanks again
Old 07-09-2006, 07:15 PM   #4
Journeyman Plumber
Ron The Plumber's Avatar
Is this a sloan flush valve, where there is no tank?
Ron The Plumber is offline   Reply With Quote
Old 07-09-2006, 07:25 PM   #5
Journeyman Plumber
Does it look like this
Old 07-09-2006, 10:18 PM   #6
there isn't a tank - it looks similar to the picture
Old 07-09-2006, 10:22 PM   #7
Journeyman Plumber
There is a shut off there, look under the crome cap, right side of valve, it's a screwdriver stop under the cap, turn it clockwise, then hit the handle to make sure it shut off.
Old 07-09-2006, 11:24 PM   #8
Can the sloan valve be left connected to the water supply coming out of the wall & the toilet fixture disconnected from the sloan valve & removed so that tile can be layed & then the fixture put back & reconnected back to the sloan valve unit thus allowing the water supply to the rest of the house to be left on while the tiling takes place?
Old 07-10-2006, 07:10 AM   #9
Journeyman Plumber
Yes it can, as a matter of fact, as long as you don't hit the handle you can disconnect it from the vaccum breaker just below the valve it's self, thats the nut seen midway on the valve, once unscrewed at that point it should become clear on the rest of the removal.
Old 07-15-2006, 05:15 PM   #10
Thanks, Ron, for the great help. It is appreciated.
Advice on commercial toilet install SoCalSwami Plumbing 9 05-15-2008 03:43 PM
moving basement toilet cibula11 Plumbing 10 10-20-2007 01:22 PM
Leaking pipe under toilet aprildawn Plumbing 4 01-21-2007 04:32 PM
Replacing a Toilet dandgluna Plumbing 8 07-10-2006 10:09 PM
Toilet; Cistern to Toilet pipe ( Complete Novice) broke1973 Plumbing 1 07-15-2005 08:34 AM
