Dishwashers & Garbage Disposals - Must They Be Installed? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-05-2012, 12:27 AM   #1
Dishwashers & Garbage Disposals - Must they be installed?
There are 2 things I don't like in my kitchen, one is the garbage disposal. It ends up causing problems and getting clogged. Are they required by code?
The second thing is the dishwasher. We rarely use it and what ends up happening is it begins to smell (trap dries out or gets stagnate). We don't have a family so we don't need a dishwasher. I assume dishwashers are NOT required by code, right?
JackOfAllTrades is offline   Reply With Quote
Old 05-05-2012, 12:31 AM   #2
Rewards Points: 13,468
No there not required.
Old 05-05-2012, 04:47 PM   #3
Neither a dishwasher nor a garbage disposal are required by code anywhere that I'd heard of.
As for the troubles you have with the dishwasher smells, does it have it's own drain and is not hooked up to discharge before the sink trap? There's just the two of us, use it about once every 5-7 days, and have never had a problem with smells.
VIPlumber is offline   Reply With Quote
Old 05-05-2012, 05:21 PM   #4
We don't use our dishwasher for months, I believe the trap dries out or gets stagnant, causing the smells.
Old 05-06-2012, 08:03 AM   #5
Rewards Points: 162
These items may not be required by code, but don't forget about resale value. Not having a dishwasher would turn off a lot of potential home buyers.
Some advice you receive on the internet can be worth exactly what you paid for it - be careful.
stubborn1 is offline   Reply With Quote
Old 05-06-2012, 11:01 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,500
Not by code...but some lenders require them to obtain a loan....especially VA.....
I can see the dishwasher leaving....especially if you don't have kids and dishes coming out the proverbial a$$.....if I was single, the dishwasher would never get used....no need to wash food wrapers.....
Garbage disposal? You sound like my MIL....she fills the thing up until water does not drain...and then turns it on....because she has so much junk in it, she didn't see the spoon.....
So....run it more often...and keep the spoons out......or just remove it....it's your house....but I think taking it out is more work than flipping the switch.
Old 05-06-2012, 11:26 AM   #7
I=E/R
a7ecorsair's Avatar
or pop cans
a7ecorsair is offline   Reply With Quote
Old 05-06-2012, 01:29 PM   #8
Homerepairguy's Avatar
Rewards Points: 998
Bad smell from the dishwasher - Do you have an airgap installed in the dishwasher's drain line? Some installers just route the dishwasher's drain line to a high point under the kitchen counter without an airgap. Although it is allowed by code in some cities, that's an extremely bad practice in my opinion.
Without an airgap in the drain line, waste water from the dishwasher could fill the garbage disposal and siphon back into the dishwasher if there's no backflow check valve in the dishwasher or if it is stuck in the open position. This would allow food particles from the garbage disposal to be siphoned back into the dishwasher causing the bad smell. With an airgap installed, that can't happen.
If an airgap is not installed in the drain line, a solution to your problem might be to install one. You may have to flush the dishwasher and drain line to clear old food particles out to get rid of the smell. Also, always run the garbage disposal prior to using the dishwasher to allow proper drainage.
HRG
Homerepairguy is offline   Reply With Quote
Old 06-10-2012, 08:41 PM   #9
DIYer
Rewards Points: 262
dishwasher smell
Hey, guys...hijacking this thread with a similar problem.
We just finished renovating our kitchen (new everything). We had a smelly dishwasher before and still do now with the new one. We figured the smell would go away with the new dishwasher, disposal, sink, plumbing, etc. but it hasn't.
We run the dishwasher about twice a week. We have done this in three houses over ten plus years and never had a smell. We rinse dishes before putting them in the dishwasher as we always have.
I have a loop where the hose goes way up high to the counter top. The sink and disposal never smell.
Surely, the engineers who design these things run enough rinse water through the machine to get all the dirty water out of the drain line. I have a hard time believing that is the problem.
I've read dozens of suggestions about using vinegar, baking soda, bleach, lemonade, tang, and even kool-aid (are your freaking kidding me?!?) and I can't believe any of this could really fix a problem with a new dishwasher.
The solution that does sound interesting is the air gap. Can some of you smart guys explain exactly how this works and why it's recommended but not required?
thanks!
mystic_cobra is offline   Reply With Quote
Twin Water Heaters Installed BigD9 Plumbing 6 04-08-2012 01:06 PM
Looking for a push button for garbage disposal docmattman Electrical 28 02-16-2011 02:56 PM
Old garbage disposal question please help. linuxguy0481 Kitchen & Bath Remodeling 3 07-26-2009 10:03 PM
Need opinion - Need help - I believe my toilet was not installed properly rdlegacy Plumbing 9 05-06-2008 05:03 PM
Just installed LG dishwasher--there's a buzzing sound. naiLS1 Appliances 1 04-15-2007 09:22 AM
