Dishwasher Water Supply Line Too Small? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-18-2011, 04:57 PM   #1
Dishwasher water supply line too small?
I recently had a GE dishwasher installed by a plumber and afterwards was reading the installation instructions. In the instruction manual it says not to use a water supply line that is smaller than 3/8". The plumber used 1/4"; now i am concerned that there is going to be a problem. Does anyone know if using a smaller water line is going to cause problems with the durability, function or performance of the dishwasher?
porpoise1877 is offline   Reply With Quote
Old 08-18-2011, 05:04 PM   #2
Rewards Points: 1,512
It is possible that the dishwasher won't fill fast enough for proper washing action. Use a clock or watch with a second hand and listen as a cycle goes through. Write down the length of time water is entering, length of time washing action is going on, and length of time the water is drained out. Typically it needs 5 minutes for washing and 2 minutes for rinsing. Usually there are two wash cycles followed by two or three rinse cycles.
If fill time is more than half of the combined fill plus wash time then you probably ahve a too slow fill problem.
Check the dishes for films or residues at the end of the cycle.
AllanJ is online now   Reply With Quote
Old 08-18-2011, 06:17 PM   #3
DIY staff
Rewards Points: 7,174
Take a picture of that please-----I can't imagine a plumber using 1/4" line--I must see that to believe it.----Mike---
Old 08-18-2011, 07:54 PM   #4
maybe plumbing standards are different between the US and Canada? When I went to Home Depot to purchase a 90 degree dishwasher supply line connection they were all 3/8" to 1/4" connections - which would imply to me that using 1/4" for water supply is fairly standard.
Old 08-18-2011, 08:00 PM   #5
DIY staff
Sorry--all I've ever seen are 1/2"x3/8" or 1/2" x1/2"----Must be something new---
Old 08-18-2011, 09:07 PM   #6
Rewards Points: 121
All the dishwashers I've seen have a floating water level sensor. It shouldn't matter how long it takes, it will reach the fill level eventually.
readar is offline   Reply With Quote
Old 08-18-2011, 10:17 PM   #7
Nope. Our market is much too small to differ from our US cousins.
Big box = junk. There's a MUCH better selection and variety at plumbing supply houses.
VIPlumber is offline   Reply With Quote
Old 08-18-2011, 10:17 PM   #8
readar - that makes perfect sense, but I wonder why GE would stipulate no smaller than 3/8"
Old 08-18-2011, 10:19 PM   #9
VIPlumber - fair enough, I just wonder why the plumber would have run 1/4", unless it was a norm.
Old 08-19-2011, 07:10 AM   #10
Rewards Points: 1,216
Not everybody has access to Plumbing Supply House and besides that they treat you like your from MARS when your not in the trade and have an account there. I know been in the business over 40 YRS.
COLDIRON is offline   Reply With Quote
Old 09-07-2011, 08:34 AM   #11
some dishwashers use a valve that let the 'correct' amount of water in regardless of the pressure (as long as it is over a certain pressure). if yours says to use a certain diameter hose, maybe its valve needs that size to get to that minimum pressure, and therefore allow the 'correct' volume. But i would think this minimum is pretty low.
correct is in quotations because there is variation. the smaller the valves variation rating the better the valve.
drh146 is offline   Reply With Quote
Tags
1/4" , dishwasher , supply line
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Dishwasher line to disposal: water in bottom of DW smawgunner Appliances 7 05-14-2011 03:37 PM
Supply valve to bath faucet doesn't stop water Kurt123 Plumbing 2 09-05-2010 09:48 PM
Water supply line on the back has a leak lauraochoaanp Appliances 3 08-31-2010 06:19 AM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 09:26 PM
