Dishwasher Water Supply Line Options - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-11-2010, 04:42 PM   #1
dishwasher water supply line options
Hello All,
Quick question.
We are remodeling the kitchen and have relocated the dishwasher so it will be next to the sink. In its previous location, it had a designated hot water supply line.
I have two options:
1. Extend the previous line (in the basement) to the new location.
2. Tap into the hot water supply for the kitchen sink.
I would rather do option 2, however, is it better to have a designated supply line for the dishwasher? Will I see a drop in hot water pressure at the sink if the dishwasher is running at the same time? Or will it not be phased? I really don't mind doing either.
Appreciate any advice/experience.
Thanks.
kenm09 is offline   Reply With Quote
Old 02-11-2010, 05:29 PM   #2
Mine taps into the Hot under the sink it was built like that no problem.
Just make sure you install a tee with a shutoff valve.
I would also use the braided flex line from the valve to the DW.
SULTINI is offline   Reply With Quote
Old 02-11-2010, 09:17 PM   #3
firehawkmph's Avatar
Rewards Points: 1,800
ditto on what Sultini said.
Mike Hawkins
firehawkmph is online now   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
New Dishwasher Water Line Leaking HELP! benchmarkman Appliances 4 12-13-2009 09:45 AM
Questions about icemaker and water line options littlehoov Appliances 2 11-04-2009 12:27 PM
Hot Water Problem osheacol Plumbing 2 06-30-2009 10:07 PM
Hot Water Recirculating Line jdupre Plumbing 9 01-06-2008 08:49 AM
