Dishwasher In Tricky Location - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-09-2011, 10:11 AM   #1
Rewards Points: 2,212
Dishwasher in tricky location
I am installing a dishwasher in my kitchen. Because of the layout of the kitchen it can not be near the sink. It is 12' away.
I can not run a vent up inside the wall it will be on the center wall of a 1973 modular house. It is built in such a way that it is impossible to run a 1.5" pipe up it.
I will have a 12" cabinet beside the dishwasher, unfortunately there is a heating duct directly below it and I can not go down through the floor joists and into the basement here.
The floor joists under the dishwasher are open.
Here is my question. Can I run the 3/4" line with a high loop behind the dishwasher, through the floor and into a 1&1/2" line with a P-trap then over the 8' to the main stack.
The 3" main stack is 8' away.
I have attached a drawing of my idea.
(Sorry for the large size, I can not get it resized smaller)
Hope this helps.
mae-ling is offline   Reply With Quote
Old 12-09-2011, 10:53 AM   #2
I realize with a bit more work I could run a re-vent.
Tie in a 1&1/2" line in the wall beside the 3" main stack. run that down and under the floor over to the dishwasher, tie in the 3/4" high loop line, then a p-trap, then into the main 3" stack.
Not sure which side of the P-trap the re-vent should tie in on, re-vent high loop P-trap or high loop p-trap re-vent (I think the second is right)
Here is a pic.
Old 03-18-2012, 11:20 PM   #3
Im totally not a plumber and asking questions just like you.
However, fwig, that reventing is right and required. But it cant revent any lower than other fixtures drains (hey, doesnt your sink/vanity have a revent too?)
There's some allowance for wet venting in some codes now (Ontario Canada for eg) but only under very specific circumstances. i think it does not apply to you here (nor me in a similar situation).
mathx is offline   Reply With Quote
Old 03-19-2012, 01:39 AM   #4
Homerepairguy's Avatar
Rewards Points: 998
Twelve feet is a long way to transport quick rinsed dirty dishes from the sink to the dishwasher. Dirty water and food particles can drip on the floor unless you use a deep tray to load the dirty dishes in for transport. The tray will be heavy and probably require multiple trips. I think that can get pretty old pretty quickly. Have you considered the human aspect of your plan?
HRG
Homerepairguy is offline   Reply With Quote
Old 03-19-2012, 05:06 AM   #5
DIY staff
Rewards Points: 7,174
Your second sketch will work---
Old 03-19-2012, 11:42 AM   #6
thanks for this information.
dstorjoh is offline   Reply With Quote
Old 03-19-2012, 12:21 PM   #7
Rewards Points: 1,594
I agree with Homerepairguy, no sensible kitchen design would have the dishwasher 12' from the sink. Whoever does the dishes will come after you with a frying pan.
bob22 is online now   Reply With Quote
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 01:10 PM
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
