Dishwasher Smell - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-26-2009, 03:13 PM   #1
dishwasher smell
I just installed a disposal and noticed that the pipe that goes from the dishwasher to the disposal was disgusting. Our dishwasher had been smelling and it was just like the smell from this pipe. I tried to clean it out during the disposal installation and it helped the dishwasher smell some. Now the smell in the dishwasher is back in full force. Any recommendations on how to clean out that pipe??
jcjeffery is offline   Reply With Quote
Old 05-26-2009, 04:56 PM   #2
Oldguy
Rehabber's Avatar
Does the drain go directly to the disposal? It should go to an air gap installed at the top of the sink first. this will prevent any 'Garbage" from going back into the dishwasher. Not very sanitary without an air gap, that why plumbing code requires one. Seen a lot of installations without one though.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 05-26-2009, 11:43 PM   #3
Oldie but Newbie
The water should pump out of the dishwasher up to a vent on your sink and then drain by gravity through a separate hose into the garbage disposal. I've seen that gravity drain hose clog and get very smelly.
You can take out that drain hose and clean it, and be sure to remove any gunk lodged in the connections.
Hook it back up and run your dishwasher with a mild solution of vinegar or maybe bleach to get rid of the smell.
LookoutRanch is offline   Reply With Quote
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Smell Under Kitchen Sink mamaerin General DIY Discussions 4 09-23-2009 12:01 PM
Sump pump smell - not sewer Thunderknight Plumbing 3 11-23-2008 09:37 PM
Gas Furnace - Burning smell at return blakemcginnis HVAC 4 01-26-2008 09:29 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
