Dishwasher Plumbing Adaptors - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-10-2010, 01:56 PM   #1
Rewards Points: 590
Dishwasher plumbing adaptors
We just pulled out our old dishwasher, and the slightly-used replacement is ready to go. Unfortunately, we ran into two problems:
1. The drain pipe end was cut down to 5/8, but our garbage disposal needs 3/4.
2. The old dishwasher had its hot water fitting on the right side, but the new one has it on its left. It's closer, but the water line is flexible copper instead of braided steel and I'm afraid we'd kink it if we tried to make the two turns to line it up.
I don't have most of the plumbing tools I'd need, and it's been decades since helped my dad with a little plumbing work, so I'd rather not cut down the hot water line and sweat on a new fitting. In addition, I'd rather keep the existing drain line and slap on an adapter if it's possible so I don't have to disturb that. Is any of this feasible? I was thinking of going to a plumbing supply and see if they can make up adapters for both of these.
operagost is offline   Reply With Quote
Old 05-11-2010, 07:03 AM   #2
The braided lines offer the most flexibility for connections. Check Sharkbite fittings at plumbing supply or home stores, there might be one that works. No soldering needed. New drain lines are also available.
The Following User Says Thank You to Just Bill For This Useful Post:
operagost (05-11-2010)
Old 05-11-2010, 10:12 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You probably won't get a sharkbite for a 3/8 soft copper...... I wouldn't do that as a permanent solution anyway, not to mention it isn't going to solve your problem.
There SHOULD be no sweating involved. Each end of the copper flex line should have a compression adapter on them. If you can get the line cut to the approximate length you need, you should have no problems..
Journeyman Plumber
Plumbing Help for installing RO Unit and Dishwasher hellothere123 Plumbing 1 10-25-2009 08:50 PM
dishwasher in Island new plumbing OLD HOUSE! What have I done Plumbing 3 09-24-2009 02:42 PM
Sewer smell after hooking into plumbing vent daveyd Plumbing 10 08-10-2009 07:25 PM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 07:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
