-   -   dishwasher leak (http://www.diychatroom.com/f7/dishwasher-leak-149585/)
amakarevic 07-08-2012 04:00 PM
dishwasher leak
My dishwasher is leaking, there is a puddle underneath it.
I was wondering how many possible causes there may be or is it easy to narrow it down to maybe a common cause (e.g. a gasket)
oh'mike 07-08-2012 04:25 PM
Most common---door leak
Next--pump failure
water feed line
drain solenoid/connection
oh'mike 07-08-2012 06:18 PM
Remove the lower cover plate--slide a sheet of paper or card board under the machine--that will show you the point of the leak--
There is exposed electric under there--so keep your hands out when the machine is operating---
ben's plumbing 07-08-2012 10:16 PM
my vote is the door seal....:laughing::laughing:
amakarevic 07-09-2012 12:30 AM
i think it is leaking from the back, because the area in the front did not have puddles.
maybe the drain out ?
oh'mike 07-09-2012 06:38 AM
No connections in the back----pump is in the middle--drain also---water feed front left---
You may need to pull it out---
If water is leaking in the back---case damaged---drain line might be one of the push in connections and it has pulled apart--or water line is flawed---or you have a vacuum breaker in the drain line and water is seeping out of it and traveling back down the line behind unit---
amakarevic 08-28-2012 04:27 PM
3 Attachment(s)
I took the DW out and it drips from the back, seems like a metal brace under where the rotating propeller is inside. The pictures are taken from the back of the appliance.
Any idea what's causing the leak?
Attachment 56455
Attachment 56454
Attachment 56456
amakarevic 08-28-2012 04:51 PM
1 Attachment(s)
Another pic from the left side
Attachment 56459
ben's plumbing 08-28-2012 06:40 PM
Attachment 56459
looks like its time for new dishwasher leak seems to be from housing around pump assy......not sure why its setting on 2x4s????? alot of parts for these things are expensive..cheaper to buy new dishwasher in comparision to age and cost of parts with labor...:yes:
amakarevic 08-28-2012 06:43 PM
2x4 so i can see better where it leaks
amakarevic 08-28-2012 10:34 PM
There has to be a cheaper fix
bob22 08-28-2012 11:02 PM
Could be pump to cabinet gasket leaking. Your eyes will have to guide you as to where the water is coming from. Gasket is cheap compared to a new machine.
amakarevic 08-29-2012 12:35 AM
I was thinking along similar lines. Cause there was a broken wine glass inside once or twice and shards could have gotten through the fins in the bottom, if underneath is where the said gasket is located.
amakarevic 09-07-2012 02:58 PM
1 Attachment(s)
The problem are the loose and leaky O ring gaskets on the motor. I called a local parts supplier and the replacement is $24 each, which is ridiculous for effectively a rubber band. Talk about racket.
Anybody have an alternative suggestion? Is there such a thing as aftermarket generic gaskets for like $0.20?
The motor is Johnson Elec DCJ72(4)MLG
Attachment 56982
chemman 09-07-2012 04:44 PM
Could try a mom and pop hardware store. They usually have all kinds of random stuff on the shelves. Or measure and order from somewhere online. I wouldn't waste my time in a home improvement store, they'll never have it.
