Dishwasher In Island With No Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-12-2011, 01:06 PM   #1
Rewards Points: 2,210
Dishwasher in island with no sink
Can anyone give me a diagram of how to plumb a dishwasher in an island with no sink? Just the discharge (waste water) plumbing. the supply line is pretty simple
mae-ling is offline   Reply With Quote
Old 12-12-2011, 08:56 PM   #2
jproffer's Avatar
Rewards Points: 706
..........................................__ Pipe --> Discharge hose
__________________________________________ Floor
...........................................put a trap down here
I don't know what you're asking, if not that....if you can handle the feed line, seems like you can handle the discharge line.
jproffer is offline   Reply With Quote
Old 12-12-2011, 09:11 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 986
see if this helps, if i can get it to load up.?
Javiles is offline   Reply With Quote
Old 12-12-2011, 10:48 PM   #4
VIPlumber is offline   Reply With Quote
Old 12-12-2011, 10:50 PM   #5
jproffer's Avatar
Rewards Points: 706
Well that blows the hell outta my dots and dashes....good show
Old 12-12-2011, 10:54 PM   #6
Just searched google images, easy as that.
Old 12-12-2011, 11:50 PM   #7
Master Plumber
Javiles's Avatar
Rewards Points: 986
Very simple, I have installed self standing dish washers on kitchen island for years... passed inspection here in Florida, Not sure about your area but it falls under UPC ...
hope this one comes up(attachment)
hard to see. vertical with a AAV installed at highest point under counter. waste arm, P trap, stand pipe just below AAV clean out at base of vertical. 2 inch pipe
Old 12-13-2011, 03:23 PM   #8
Thanks for the replies. Not a big fan of AAV. will use the island loop.
A question
I figure With the loop I just use a nipple in the top of the P-trap. and connect the dishwasher hose to that.
Old 12-16-2011, 09:07 PM   #9
Ugh - There is to much duct work in the way (for the hot air furnace)
Here is a thought I had that I could get to work.
(Sorry for the large size could not get it to resize smaller)
Take the discharge hose from the dishwasher, do the high loop behind or beside the dishwasher, take it down through the floor, run it 2 feet horizontal to get over ductwork and into the top of a p-trap. then it is 7 feet horizontal to the main 3inch stack.
for the venting -
There is an existing 2" fixture vent line for the basement bathroom that I can access. This ties into the main stack above the fixtures on the 1st floor. I would Tee off this just below the floor joists and tie it into the drain line just before the p-trap.
Hopefully it is clear in the picture.
Old 12-16-2011, 10:59 PM   #10
I can do an island loop if I can keep where it comes through the floor at about 10" wide. Then use 45degree joiners to widen it so I can put the P-trap inbetween the vent half of the loop and the drain half. (between the two uprights) This would put the p-trap right behind the dishwasher.
I am building the cabinet and counter-top myself and can make it 26 or even up to 30" deep if needed.
conversion of portable dishwasher to stationary one grimsbyman Plumbing 15 02-13-2014 11:45 AM
Dishwasher Drain Install w/o Sink Lyndon Plumbing 3 11-21-2011 02:10 PM
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 11:56 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
