Old 09-27-2012, 12:36 PM   #1
Dishwasher installation
Can I use Shark Bite connectors and Pex tubing for dishwasher installation? What size tubing should be used for output from dishwasher?
STARLINKK is offline   Reply With Quote
Old 09-27-2012, 04:54 PM   #2
for the drain we always used 5/8 id rubber hose.
Old 09-27-2012, 05:11 PM   #3
You might want to consider using a braided hose which will give you flexibility to jostle your dishwasher into position and connect to the water supply.
Also for the waste pipe, I prefer to use stainless steel worm gear clamps over quick assemble clamps (this comes with your dishwasher).
Good luck
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
ben's plumbing (09-27-2012)
Old 09-27-2012, 07:20 PM   #4
diden't the d.w come with its own drain hose.....and we always use braided supply 3/8 x 3/8 .......
Old 09-29-2012, 12:00 PM   #5
The drain hose supplied is too short. I have to go about eight feet.
Could I use the Shark Bite connectors and Pex hosing?
dishwasher installation - why dedicated circuit? DanDaMan Electrical 4 03-03-2011 01:49 AM
Dishwasher installation is supposed to be easier than this ... jacoite Appliances 7 07-07-2010 11:08 AM
New dishwasher installation PirateKatz General Discussion 3 03-08-2009 02:35 PM
Dishwasher installation Andy Griffith General Discussion 3 03-02-2009 07:06 AM
Dishwasher Installation champy2008 Appliances 4 01-07-2009 11:06 AM
