Dishwasher Install Re: How To Turn Off Hot Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-26-2014, 09:44 AM   #1
Dishwasher Install re: How to turn off hot water
Hi Everyone,
I have a 5/8 compression x 3/8 x 38 water shut off valve I plan on installing tonight so I can hook up the hot water line from dishwasher and also the kitchen sink faucet.
Before I start, I have a question on how I should shut off the hot water before I cut into the 1/2" copper pipe for the new water shut off compression fitting.
Would it be OK if I shut off the water outlet which is located directly above the hot water heater. I would not touch the cold water inlet as this would still be on.
Underneath the kitchen sink on main level is a washroom in the basement, I would open this hot water tap to drain the water from above hot water lines.
Always wondered what the best way to work on the hot water lines of a system, and if you should close the hot water outlet or cold water inlet connected to the gas tank before starting to do any work.
My logic is if I turn the hot water outlet, this is no different then all the taps in the system being closed.
wguttrid is offline   Reply With Quote
Old 03-26-2014, 01:38 PM   #2
Rewards Points: 20
That should do the trick. Enjoy the new dishwasher.
SHR Plumber is offline   Reply With Quote
Old 03-26-2014, 02:09 PM   #3
Thanks SHR Plumber, always worried about shutting down a valve off the hot water tank heater.
For whatever reason, always have in the back of my head a fear that if I turn a valve off from the hot water tank heater while doing some work the tank is going to explode on me.
Sometimes worry to much I suppose.
Old 03-26-2014, 02:48 PM   #4
Rewards Points: 20
I would rather have you worry than turn your house into a YouTube video!
Old 03-26-2014, 03:29 PM   #5
DIY staff
Rewards Points: 7,174
May I suggest you shut off the water at the meter?
If you have single handled faucets ,you might get some cross over when you attempt to drain the pipes---If you have old fashioned gate valves---be careful--they often go bad---if there is a ball valve at the main--use that---
Old 03-26-2014, 03:29 PM   #6
SHR Plumber, very true! Caution is a good thing! LOL.
I am headed home to get this dishwasher hooked up finally, hot water is the last step as everything else is done and wanted to double check before I start closing valves.
Old 03-26-2014, 03:32 PM   #7
oh' mike...thanks for the heads up! I will make sure I close the cold water shut off valve under the sink to ensure things don't loop around the single faucet head. I believe they are newer style valves on the water tank as it is newer. Will double check.
Old 03-26-2014, 03:41 PM   #8
DIY staff
Good plan---I always just shut off the main ----never just the hot water valve---
It should work---so do what ever is easiest for you---
Old 03-26-2014, 05:20 PM   #9
Rewards Points: 582
I love to see a plan come together..2 heads are better than one...well for thinking anyway not sure how one would look
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (03-27-2014)
Old 03-26-2014, 05:23 PM   #10
Rewards Points: 980
Turn heater to pilot or off.
vacuum breaker question detroittigerfan Plumbing 17 10-12-2013 01:37 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 07:14 PM
water damage from high pressure aeldien Plumbing 9 04-16-2012 11:21 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
water supply line to a new dishwasher install phillips48bpd Plumbing 5 09-07-2011 07:09 AM
