Dishwasher Install - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2011, 10:29 AM   #1
Rewards Points: 190
Dishwasher Install
hooking up my dishwasher. It is in a new location. The previous owners had a rubber tube coming from the dishwasher looped up on the cabinet then down to the basement directly into the main sewage pipe. The adaptor they have on the sewage line (not sure what its call) the rubber tub goes over it and fits snug. Is this a correct way for drainage?
The previous owner's dishwasher was not working, so they removed the power line to it and the hot water line. I see the hot water line where they cut it off a valve in the basement, will probably just connect a new line to that and run it through the floor. Should a dishwasher be on its own breaker? From what I can see looks like they just tapped into a junction box below where the dishwasher was (junction box is in the basement).
ryanb4614 is offline   Reply With Quote
Old 12-31-2011, 11:06 AM   #2
MarginallyQualified
Rewards Points: 2,464
No. Not even close to correct.
Is there a (good) reason the DW is not being installed NEXT TO THE SINK?
How about solving the butchered up plumbing issues first?
Then you can move on to fixing the butchered up electrical.
hth
Old 12-31-2011, 06:09 PM   #3
Rewards Points: 582
get us some pictures if you can....may be a good reason why it was done like that....yes to the electrical should have its own circuit....thats best....need to see some of the plumbing to see whats going on ...don't panic...ben
dishwasher install - replacing copper feh Plumbing 7 03-21-2012 03:12 PM
New dishwasher install -- plumbing help kb01 Plumbing 3 04-23-2011 11:51 AM
Dishwasher powder instead of salt - Doh! Bottletops General DIY Discussions 0 03-03-2010 11:06 AM
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 10:05 AM
Install a dishwasher in an existing kitchen cabinet shapeshifter Remodeling 9 03-16-2008 01:05 PM
