Dishwasher Inlet - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-12-2011, 11:33 AM   #1
Dishwasher inlet
We just bought a house and the dishwasher didn't work. The intake works because I turned it on and the water came out very fast. Just bought a new Kitchen Aid dishwasher from Sears and now I'm wondering: do I need to use a steel braid intake pipe or can I use what's there (see picture)? It seems that Home Depot and Sears only sell the steel braid stuff, at least here in Canada, rather than this white plastic. I have no idea what the difference is. I just don't want a flooding incident in the future, and I don't mind paying for a plumber to change it to braided... any advice is greatly appreciated. Thanks.
djgrant is offline   Reply With Quote
Old 07-12-2011, 03:52 PM   #2
I'd only change the pipe from pex (your white plastic pipe) to braided ss where the pipe leaves the wall/floor behind your dishwasher. It's easier kink pex than braided if the new unit ever needs to be serviced or replaced.
VIPlumber is offline   Reply With Quote
Old 07-12-2011, 03:52 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro plumber, but that appears to be PEX. If I were you, I would have it replumbed with the stainless steel flex hose made for dishwashers. Then it will be easier to change or work with in the future.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 07-12-2011, 04:02 PM   #4
Anyone know why there is that type of valve on there instead of the kind that you see in bathrooms for example?
Old 07-12-2011, 04:43 PM   #5
Experienced
Jackofall1's Avatar
Its simply a better valve, the valve is known as a ball valve much better than the seat and seal valves normally provided by builders. The reason builders generally don't provide ball valves as shut-offs is expense.
Mark
Old 07-12-2011, 04:44 PM   #6
Should I get the valve changed as well while the plumber is there?
Old 07-12-2011, 05:15 PM   #7
Experienced
Jackofall1's Avatar
No need to change the valve, ball valves will last lets say forever.
Mark
Old 07-12-2011, 05:17 PM   #8
Oh, I see, I got confused...you said mine is the better valve. Ok, great, thanks!
Dishwasher connection and wiring, oh boy! Bigplanz Electrical 18 06-15-2011 09:52 PM
Replacing Dishwasher, No water shutoff sustorm Plumbing 24 04-08-2011 12:56 PM
Leak from water supply line & inlet elbow in newly installed dishwasher jrinco11 Plumbing 7 09-22-2010 07:39 PM
Dishwasher water inlet valve question Schweinehund Plumbing 0 01-29-2010 01:37 PM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
