Dishwasher Drain Pipe Fitting - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-27-2013, 12:56 PM   #1
Always learning...
fetzer85's Avatar
Rewards Points: 262
Dishwasher drain pipe fitting
I need some room above the trap to install the dishwasher drain piece, is there any issue with moving the trap down? Right now the bottom of the trap is 16.5" above the floor. I didn't know if there were any codes requiring traps to be a certain height off the floor. Thanks for your input.
John
fetzer85 is offline   Reply With Quote
Old 03-27-2013, 06:03 PM   #2
As far as I know, the trap in that picture is not to code regardless.
toluene_hawk is offline   Reply With Quote
The Following User Says Thank You to toluene_hawk For This Useful Post:
oh'mike (03-28-2013)
Old 03-27-2013, 06:31 PM   #3
Always learning...
fetzer85's Avatar
Rewards Points: 262
Ok...what's not to code?
Old 03-27-2013, 07:07 PM   #4
Rewards Points: 6
It's am S-trap.
Dan
djlandkpl is offline   Reply With Quote
Old 03-27-2013, 07:30 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
A trap that goes straight down to the drain is an" S" , no longer permittted by code. It is subject to being siphoned dry as it is not vented properly.
Code now calls for a "P" trap that goes horizontally into the junction of the drain and the vent.
As far as I know, your S trap would be grandfathered and you can add a longer tail piece and lower the trap.
Coastal South Carolina
Old 03-27-2013, 07:36 PM   #6
JDC
Plumbing Contractor
JDC's Avatar
Rewards Points: 262
Yes, it's an S trap and if I came to your house and did some work on the sink drain I'd have to bring it up to code...around here anyway. However, you own it and I assume you arent having it inspected. Lowering the trap isnt going to be an issue.
Good luck
JDC is offline   Reply With Quote
Old 03-27-2013, 07:58 PM   #7
Roofmaster
Rewards Points: 2,172
So methane gas in your house is OK as long as you are "Grandfathered"? That is one really intelligent approach.
Old 03-27-2013, 08:14 PM   #8
A "Handy Husband"
rjniles's Avatar
S traps have been around for many years and most in fact do not siphon dry. Although methane is a odorless gas, the other components in sewer gas make a very noticeable odor. If the OP has not had a problem in the past, adding a longer tailpiece will not cause a problem to appear.
The Following User Says Thank You to rjniles For This Useful Post:
Old 03-27-2013, 08:15 PM   #9
Rewards Points: 1,690
Not grand fatherd by this inspector. That S trap is a health and safety issue and can be easily fixed with a p trap and a tee and AAV vent.
The Following 2 Users Say Thank You to Ghostmaker For This Useful Post:
jagans (03-28-2013), oh'mike (03-28-2013)
Old 03-28-2013, 12:31 AM   #10
Always learning...
fetzer85's Avatar
Rewards Points: 262
Thanks for the info everyone, I always appreciate your code knowledge. Plumbing aisle here I come...
The Following User Says Thank You to fetzer85 For This Useful Post:
Old 03-28-2013, 09:30 PM   #11
Master Plumber
Javiles's Avatar
Rewards Points: 984
Ghostmaker is 100% on the money, someone could be suffering from methane gas poisoning and not even know it.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
jagans (03-28-2013)
Old 03-28-2013, 09:50 PM   #12
Roofmaster
Absolutely. An AAV could be installed very easily and eliminate the threat. Why take a chance for 10 bucks worth of fittings?
Old 03-28-2013, 11:57 PM   #13
Always learning...
fetzer85's Avatar
Rewards Points: 262
Totally agree w/ you guys. I'm going to get a hold of the building/plumbing inspector and find out if AAV's are allowed here.
Old 03-29-2013, 12:11 AM   #14
Plumber
TheEplumber's Avatar
Rewards Points: 348
You really don't have any other easy way to vent it. Google "AAV Vent" (images)
Old 03-29-2013, 12:52 AM   #15
Always learning...
fetzer85's Avatar
Rewards Points: 262
Well if I absolutely needed to I could plumb in a p trap with a horizontal section long enough to break the siphon. It might not look great but I think it would satisfy code. Do you need an actual vent w/ a double sink?
What is this thing?? Todd54 Plumbing 10 05-09-2012 05:18 AM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 09:14 PM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 07:38 AM
Washing Machine Drain Pipe tjeieio Plumbing 2 02-25-2010 06:19 PM
drain pipe size for kitchen sink, garbage disposal, and dishwasher ? amakarevic Plumbing 5 08-05-2007 01:23 AM
