Dishwasher Drain Installation Q's - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-11-2010, 12:44 PM   #1
Rewards Points: 150
Got a friend wanting me to help instal a dishwasher, which in and of itself is easy. However, here's the challenge. It will be installed in an island, 5 feet from the sink. I can access from the basement , and the plumbing passes right under the island area, so the water is no problem, the question is about the drain. Can a "T" be cut into the 1-1/2" pcv for the drain (I'm sure it can), but will it need to be vented? What would be the best way to vent? Tying into the vent stack would not be easy, as that is still cast iron. Thoughts or ideas appreciated.
TJ_in_IL is offline   Reply With Quote
Old 11-11-2010, 12:53 PM   #2
Rewards Points: 1,418
The end of the existing drain hose must fit loosely into a drain pipe although it can be clamped firmly onto the stud provided in a sink disposer. Do not splice onto the hose.
I'm not sure of the minimum dimensions needed but a drain pipe into which the hose end is inserted directly must start with a vertical and then go to a trap (not sure of how long a horizontal between the initial vertical and the trap can be.)
Old 11-11-2010, 12:56 PM   #3
Rewards Points: 150
Sure, don't know why I didn't think of it. Sort of like a washing machine drain setup.
Thanks for the revelation.
Old 11-11-2010, 03:33 PM   #4
Homerepairguy's Avatar
Rewards Points: 990
Info in this link may answer some of your questions:
dishwasher drain
HRG
Homerepairguy is offline   Reply With Quote
Very slow drain no drain blues Plumbing 16 04-03-2012 06:39 PM
Help with new dishwasher drain backing up dtmbizzle Plumbing 10 10-05-2011 11:18 AM
dishwasher drain hose onelson Plumbing 4 03-16-2010 10:55 PM
Shower drain installation cjf1980 Plumbing 8 03-10-2010 11:33 AM
Dishwasher don't drain all the way MattCoops Appliances 8 04-17-2007 11:07 PM
