Dishwasher Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-12-2012, 08:31 PM   #1
bphilip's Avatar
Dishwasher drain
I Am installing a new built in dishwasher , but it is a long way from the sink. There is easy access under the floor to the drain, but the instructions are pretty strongly saying I have to connect it above the sink trap. I don't see why this should be necessary since the drain hose from the dishwasher first loops from the bottom drain of the unit , around the side of the unit and up nearly to the top of the unit before dropping back down to the floor. Isn't that a sufficient trap?
bphilip is offline   Reply With Quote
Old 04-12-2012, 08:50 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No it isn't. It doesn't have a vent, so it doesn't act as a proper trap. It could siphon itself out and . . . . well you know the rest.
Is there some structural preclusion that doesn't allow you to run it to the sink?
Journeyman Plumber
Old 04-12-2012, 10:21 PM   #3
bphilip's Avatar
The dish washer ended up about 12 ft from the sink and on a different wall. It's a u shaped kitchen with the sink at the bottom of the u and the dish washer at one end. I could put a trap in the abs under the floor but I guess that wouldn't help the venting.
Old 04-12-2012, 11:45 PM   #4
Doing it myself
Alan's Avatar
If you can get under the floor to put a trap under there, you might as well run it over to the sink and up through the bottom of the cabinet.
Journeyman Plumber
Old 04-13-2012, 06:31 AM   #5
Rewards Points: 1,596
That's a longggggggggggggg way from sink to DW. Do you intend on using the DW? Might want to rethink location IMO.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
Alan (04-13-2012)
Old 04-13-2012, 09:01 AM   #6
Doing it myself
Alan's Avatar
Good point. This all assuming that you're not exceeding the output capabilities of the pump.
Journeyman Plumber
Old 04-13-2012, 09:25 AM   #7
bphilip's Avatar
So...Just putting a trap in the crawl space under the floor won't cut it?
Old 04-13-2012, 09:37 AM   #8
Rewards Points: 150
Can it be properly vented?
psilva8 is offline   Reply With Quote
Old 04-13-2012, 09:57 AM   #9
bphilip's Avatar
The sink drain is vented through the roof. I'm not sure if that would be enough venting for the dishwasher. The kitchen is a U shape with the sink and vent at the bottom of the U, and the dishwasher at one end. The drain pipe from the sink goes straight up the middle of the U and out the top to the main stack, and I currently have the DW draining into a T connection at the top of the U. From the vent stack to the T is about 6 ft, and from the DW to the T is about 5 ft.
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Help with new dishwasher drain backing up dtmbizzle Plumbing 10 10-05-2011 10:18 AM
dishwasher drain beech Plumbing 3 11-05-2010 06:18 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 09:55 PM
Kenmore Portable Dishwasher Won't Drain - PLEASE Help! katb1030 Appliances 8 07-10-2008 12:38 PM
