-   -   Dishwasher drain (http://www.diychatroom.com/f7/dishwasher-drain-140127/)
bphilip 04-12-2012 09:31 PM
Dishwasher drain
I Am installing a new built in dishwasher , but it is a long way from the sink. There is easy access under the floor to the drain, but the instructions are pretty strongly saying I have to connect it above the sink trap. I don't see why this should be necessary since the drain hose from the dishwasher first loops from the bottom drain of the unit , around the side of the unit and up nearly to the top of the unit before dropping back down to the floor. Isn't that a sufficient trap?
Alan 04-12-2012 09:50 PM
No it isn't. It doesn't have a vent, so it doesn't act as a proper trap. It could siphon itself out and . . . . well you know the rest. :sick::nuke:
Is there some structural preclusion that doesn't allow you to run it to the sink?
bphilip 04-12-2012 11:21 PM
The dish washer ended up about 12 ft from the sink and on a different wall. It's a u shaped kitchen with the sink at the bottom of the u and the dish washer at one end. I could put a trap in the abs under the floor but I guess that wouldn't help the venting.
Alan 04-13-2012 12:45 AM
If you can get under the floor to put a trap under there, you might as well run it over to the sink and up through the bottom of the cabinet.
:huh:
bob22 04-13-2012 07:31 AM
That's a longggggggggggggg way from sink to DW. Do you intend on using the DW? Might want to rethink location IMO.
Alan 04-13-2012 10:01 AM
Good point. This all assuming that you're not exceeding the output capabilities of the pump.
:thumbup:
bphilip 04-13-2012 10:25 AM
So...Just putting a trap in the crawl space under the floor won't cut it?
psilva8 04-13-2012 10:37 AM
Can it be properly vented?
bphilip 04-13-2012 10:57 AM
The sink drain is vented through the roof. I'm not sure if that would be enough venting for the dishwasher. The kitchen is a U shape with the sink and vent at the bottom of the U, and the dishwasher at one end. The drain pipe from the sink goes straight up the middle of the U and out the top to the main stack, and I currently have the DW draining into a T connection at the top of the U. From the vent stack to the T is about 6 ft, and from the DW to the T is about 5 ft.
