Dishwasher Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-28-2012, 01:07 PM   #1
Dishwasher Drain
Our dishwasher drain hose goes into a separate pipe w/o a p-trap then we have the main drain pipe w/ 2 sinks and disposal hooked to it. This separate pipe must be clogged as there is water spewing out when I use the dishwasher - any ideas why there is a separate pipe and why isn't there a p-trap - actually not sure how it could be clogged as nothing but the dishwasher water goes to it.
mfreske is offline   Reply With Quote
Old 03-28-2012, 01:30 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Can you supply a pic?
The pressure coming out of the dw discharge is what may be causing the water to come back out of the drain.
one way to do it.........
sublime2 is offline   Reply With Quote
Old 03-28-2012, 09:36 PM   #3
First of all don't you smell sewer gas when you open the dw? Secondly how well do you rinse you dishes or clean the sump in the dw? It may be that the debris from your dishes is clogging the drain line.
VIPlumber is offline   Reply With Quote
drain hose for new dishwasher -doesn't match old one? denemante Plumbing 1 11-01-2011 12:57 PM
Help with new dishwasher drain backing up dtmbizzle Plumbing 10 10-05-2011 10:18 AM
dishwasher drain beech Plumbing 3 11-05-2010 06:18 PM
dishwasher drain hose onelson Plumbing 4 03-16-2010 09:55 PM
Kenmore Portable Dishwasher Won't Drain - PLEASE Help! katb1030 Appliances 8 07-10-2008 12:38 PM
