Dishwasher Aerator On Sink - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 10:30 PM   #1
Dishwasher aerator on sink
I've bought a faucet with spray for a 4-hole sink, but I now see that one of the holes on my kitchen sink is used by the dishwasher/garbage disposal aerator. I need this fourth hole for the spray hose. Can I just unhook the aerator from the sink and just let it dangle under the cabinet? Or should I cut another separate hole for the spray hose? Or is it better to just return the faucet and get a different 3-hole faucet? (I like the separate hot/cold knobs better though)
greenjelly is offline   Reply With Quote
Old 08-05-2010, 11:27 PM   #2
Owner
LateralConcepts's Avatar
You'll need to return the faucet. Perhaps a double handle with pull out sprayer
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Old 08-06-2010, 08:48 AM   #3
You could start by checking with your local Plumbing Code office. Some areas have removed the requirement for installing an Air Gap on dishwasher drain lines. They can also tell you what is permissible if you must keep it.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-06-2010, 10:03 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Around here, in place of an airgap we just have to run the dishwasher hose up high and secure it to the bottom of the countertop.
Just so you know what its for :
It's not an aerator, it's an air gap, and it prevents your kitchen sink water from backing up into your dishwasher and dumping out all over your kitchen floor. If you let it dangle under the sink you are kind of defeating its purpose.
Journeyman Plumber
Old 08-06-2010, 10:59 AM   #5
Thanks for the replies! I remember the home inspector mentioning its purpose. I was going to tape it to the top underside of the cabinet. I live in Maryland. Is it permissible and safe to do that? Otherwise I'll just exchange the faucet tonight.
Old 08-06-2010, 12:22 PM   #6
The main problem with doing that is it may malfunction later, and cause water to flow under the counter top, and ruin the cabinet, flooring or other items stored there, without you noticing it. If I were you, and considering moving the Air Gap, I would remove it and attach the hose from the DW to the underside of the cabinet so siphoning (which is the reason for the Air Gap) would not be a problem.
temporary set up in utility room for kitchen renovation (sink; dishwasher) ilyaz Plumbing 3 01-25-2010 07:07 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 06:53 PM
Dishwasher Drain - Not by sink jamiedolan Plumbing 2 09-09-2008 11:56 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 03:32 PM
leaking under sink when dishwasher on Big B Plumbing 2 06-07-2006 07:36 PM
