Dishwasher - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-31-2009, 09:25 PM   #1
Dishwasher
Ok today my husband remove the old dishwasher,for a while until we purchase the new one.But the problem comes in with the water valve that comes from the disher to underneath the sink we have cut off the valve cut off the outside.Basically turn the hole main line off and there is still water leaking from this here valve is there anyway that I can cap this off from underneath the sink until the new dishwasher arrives cause my house need water.But even with that valve shut off even the hot water valve cutt off this thing is still running water.I have to cut the hole house off from water.Please help.
mrsgstevenson is offline   Reply With Quote
Old 01-01-2010, 06:39 AM   #2
Remodeling Contractor
Turn off the main water valve. cut the pipe under the sink before (supply side) the valves that are not shutting off completely. (you can replace these latter) No slide a sharkbite end cap fitting over the pipe. Turn on the main valve. The sharkbite can be removed latter to attach a new valve.
Old 01-01-2010, 12:57 PM   #3
firehawkmph's Avatar
Rewards Points: 1,902
Mrs. Stevenson,
Even though you shut the main off, you are probably getting water draining down from water lines above the sink area. Do you live in a two story home by chance? If you want to get it to stop dripping in this situation, shut off the main, then open up the faucets and shower controls upstairs, and open up a faucet below if you have a basement. Everything should drain then. In the meantime, you can make the repairs as Bob said.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Kenmore dishwasher shoots water out the side! tigerbalm2424 Appliances 7 02-02-2010 07:55 PM
Thinking about installing a dishwasher kossuth Appliances 1 09-23-2009 10:05 AM
Dishwasher installation Andy Griffith General DIY Discussions 3 03-02-2009 06:06 AM
Dishwasher placement jkrodger Remodeling 2 08-03-2007 02:32 PM
Poratable Dishwasher help oiram Appliances 4 02-09-2007 04:28 PM
