Disgusting Water - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2009, 12:48 AM   #1
Disgusting Water
About a month ago I bought a new fridge that has water and ice. So I soldered 1/2 copper to an ox box in the wall and have braided stainless steel going to the fridge. Well today the water tastes bitter. I had just broken it in and got the plastic taste flushed out and now this. It is a brand new Whirpool if that helps. I did buy the extended warranty but the service company still wants to charge me $70 for mileage so I want to try and figure out the problem first. Oh and all the other water in the house tastes normal, maybe a little chloriney.
Nick Lee is offline   Reply With Quote
Old 08-05-2009, 01:05 AM   #2
Master Plumber Lon
Send a message via Yahoo to lonsplumbing
bad taste
Change the supply line first thats the cheepest.
lonsplumbing is offline   Reply With Quote
Old 08-05-2009, 01:06 AM   #3
Master Plumber Lon
It may be the rubber in the line of the stainless.
Old 08-05-2009, 09:04 AM   #4
I can try this, what is the likelyhood this is the problem?
Old 08-05-2009, 11:38 AM   #5
Disgusting water
If you soldered a copper joint, you may have used too much flux. In any case, you should flush the water line thoroughly and then reinstall it. You also may want to consider installing an icemaker filter on your water line. Hope this helps.
JerryWatson is offline   Reply With Quote
Old 08-05-2009, 11:50 AM   #6
I was thinking about the flux, but I flushed the line before hooking up the fridge. Also I have been running water out of it trouble free for a few weeks now. I will however try and flush it tonight, that seems like the cheapest and easiest solution.
Old 08-05-2009, 11:58 AM   #7
Disgusting water
Another option I forgot to mention, Nick, might be to replace the stainless steel braided line with semi-rigid plastic tubing. You might find that this will also correct the problem. Good luck!
Old 08-05-2009, 12:34 PM   #8
I thought Braided stainless is supposed to be the best? You are the second person who thinks it might be the problem. I'm gonna have to check it out.
Old 08-05-2009, 07:31 PM   #9
Master Plumber Lon
Poly line is better for taste. Use a filter to.
Old 08-15-2009, 01:25 PM   #10
Yahtzee
Sorry I have been gone a few weeks and finally got a chance to look at the fridge. I took the fridge out and tasted the water coming from the supply line and it smelled so bad I didn't even have to taste it. THen I tried the water coming from the cutoff valve it was connected to, and it was normal. SO now I guess I have to go get a new supply line. I was thinking cpvc braided line, or would that possibley give me the same problems as stainless?
Thanks for the help guys!
Old 08-15-2009, 11:00 PM   #11
Yippey!
I replaced the line with semi ridgid Poly and the taste is gone!!!
I decided to do that over cpvc, since I figured it was the safest for no taste. There is a plasticy taste but I'm sure it will go away like the first time.
Thanks for everyone's help!!!
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
